Old 02-10-2020, 07:52 PM   #1
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
Tilton ST-246 Clutch - If it works as good as it looks...
Kind of went out on a limb - have not heard of anyone running these yet, but know their reputation for racing clutches is excellent.
this consists of one type of clutch pack for multiple applications (Camaro, Corvette, Mustang, etc....) thru different flywheels.
I work in the manufacturing world (was a machinist / toolmaker 15 years ago) and this is one really nicely made unit. The flywheel is like a piece of art.
It is not a big thick flat disc, on the engine side it is all relieved for weight
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 03-30-2020, 01:16 PM   #2
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Hi, can I ask if your Clutch was worn and slipping since your installing a new set up? And if so about how many miles did you get out of it? I’ve never had a manual on a high Hp car before. So I wondering how much abuse use launches you can get.
Thanks
2004YZFR1 is offline   Reply With Quote
Old 03-30-2020, 01:55 PM   #3
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
It does look very well made, hope it turns out the best... I just bought a mcleod one... but the Tilton looks kinda like a mantic they just look like another level.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 08-01-2020, 07:13 PM   #4
Bkob1471
Drives: 2010 Camaro 1SS M6
I have been looking very hard at this clutch and have seen zero reviews of it yet. Would you be able to tell us about how this has worked out for you so far? I’m ready to pull the trigger on this one so long as the chatter is somewhat contained and it has good street manners. Thank you!
Bkob1471 is offline   Reply With Quote
Old 02-25-2021, 02:20 PM   #5
cdb95z28
cdb95z28's Avatar
Did you install this clutch? How was the pedal feel vs OE?
cdb95z28 is online now   Reply With Quote
