05-21-2016, 12:21 PM | #1 |
Drives: Camaro 1LE Join Date: Nov 2015
Fitting 4 Wheels in Car
Any suggestions on how to fit 4 wheels (+ tires) in the Camaro? I have separate wheels and tires for DD vs Track.
So far the best solution I've found is to get a trailer hitch. My previous car was a hatchback and I could fit 6 wheels + tires in the car! Thanks in advance for your ideas. |
05-21-2016, 12:28 PM | #2 |
I actually saw a guy do this, he had the rear seat out.
05-21-2016, 12:46 PM | #3 |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
I have carried 4 305 wheels and tires. 1 in the trunk 2 in the back seats and 1 in the front passenger seat. I had them all wrapped in bags as well.
Sent from my campfire using smoke signals |
05-21-2016, 12:49 PM | #4 |
Oh wow, amazing that they'd fit in the car with the rear seat out. I was thinking it was impossible.
I can't take my rear seats out though, I'm in the stock classes when I race :( Edit: Really?!? They'll all fit in the car even w/ the rear seats in? I'll have to give it a shot in emergencies. Last edited by nilfinite; 05-30-2016 at 08:20 PM. |
05-21-2016, 01:07 PM | #5 |
I guess the best way of doing all this without getting dirt and brake dust all over the rear seats is to have the rear seats down? Finagling the wheels through the passenger door into the rear should be fun.
05-21-2016, 04:38 PM | #6 |
Liv'n The Dream!
Contact h018871.
He has a trailer and a "hidden" hitch on his 1LE and tows a small trailer with a full set of tires/wheels, a truck bed tool box and other goodies. Tells me it tows it real easy. A Harbor Freight trailer for the base I think. Worked great when we went to the track. http://www.camaro5.com/forums/showth...=332717&page=9
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
05-21-2016, 06:51 PM | #7 |
Drives: 2014 2ss 1le Join Date: Sep 2011
A guy bought my SS wheels and tires. He fit all four in his camaro. One in the trunk, two in the rear seat and one in the passenger seat. It isn't pretty but it is doable.
05-22-2016, 10:26 PM | #8 | |
Although I probably wouldn't modify the hitch like he did. If we don't have to cut into the plastic, why do it? Anyone think I could get away with just a cargo carrier vs an actual trailer? I'm really glad to know that all the wheels will fit in the car. Will be helpful in a pinch. I couldn't do that to my leather seats though. Putting brake dust-covered wheels that would wrinkle and dirty the seats makes that a no-go for me. |
05-23-2016, 04:26 PM | #9 |
Thinking I'm going to go for a cargo carrier. Will just make sure to load it as light as possible.
http://www.corvetteforum.com/forums/...trailer-2.html That way don't have to deal with the lower speed limits and worrying about the trailer doing crazy things. Will have to make sure to get a hitch that has the appropriate tongue weight rating. |
05-24-2016, 09:18 AM | #10 |
Drives: 2014 Camaro 2SS 1LE /2011 2LT Join Date: Sep 2015
Lol, I did the same thing, just don't pull to much G, otherwise that front seat tire will be in your face
05-30-2016, 05:52 PM | #11 |
Has anyone tried loading two wheels through the trunk? 1 wheel through the rear seat passthrough and another in the trunk? Is the passthrough space tall enough to fit a wheel?
The cargo carrier + 2 wheels gets very close to the 200 lb tongue weight restriction. Trying to avoid the trailer idea. The hassle of registering the trailer, hooking up lighting, finding storage space, building a trailer to my specs is so much work! At that point, might as well get a dedicated enclosed trailer. |
06-10-2016, 10:05 PM | #12 |
On this front. Tried loading two wheels in the trunk today. 1 partially in the wheel well and the other partially through the passthrough.
Doing it once, not planning on doing it often. The wheel barely fits through the trunk opening and the trunk passthrough. These are narrow 285/35/20 Comp 2 A/S tires. Wider racing tires will not fit. Also lifting 60-65 pounds at an odd angle while trying to not scratch the car/wheel is not great. The wheel also poorly fits in the wheel well. Probably the same as leaving the trunk floor in place. Now the solution is either: 1. Two Wheels on Roof Rack + Two Wheels on Hitch-mounted Cargo Carrier 2. Four Wheels on Hitch-mounted Trailer Leaning towards a trailer for ease-of-use but will need to figure out storage. |
07-21-2016, 09:53 AM | #13 | |
Drives: Summit White 2016 2SS Join Date: Jan 2015
I used search looking for an answer, so flame away pedantics!
2015 1LE sold
2016 2SS sold |
07-21-2016, 10:37 AM | #14 | |
Recommend getting RE-71Rs in 19" if you are close to the top in your group in are aiming to win PAX or whatnot. |
