06-10-2020, 01:56 PM | #1 |
Drives: 18 Black ZL1-1LE Join Date: Jun 2017
Rear sway bar on zl1-1le
Was at Road Atlanta a few weeks back and the car felt very loose in corners and even under heavy braking . I am going to add 1/8 inch rear toe but I was also thinking that moving the rear sway bar from the middle hole to the forward hole will tighten it up some also. Has anyone moved theirs yet and what was the result ?
Thanks for any input! |
06-11-2020, 04:40 PM | #2 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Where was the rear bar set to at RA? A pic would be very helpful
06-11-2020, 04:57 PM | #3 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I'd first double-check you PDR/data/video to see if you weren't just doing something to induce the issue. If not, think back to your air pressures. If that isn't it... If what is being felt is fairly minor, try just the sway bar adjustment. If what is being felt is fairly significant, yeah, start looking at alignment settings. Leave the sway bar alone and adjust it at the track if you still need. |
06-11-2020, 11:24 PM | #4 |
Drives: BMW M3, ZL1 1LE Join Date: Mar 2019
I’ve tried the different swaybar settings and softening it up does indeed reduce oversteer. It’s a simple change to make so no harm in trying it out.
06-12-2020, 07:21 AM | #5 | |
06-12-2020, 07:22 AM | #6 |
06-12-2020, 07:23 AM | #7 |
06-12-2020, 11:33 AM | #8 | |
Curious, are you saying you will add 1/8 toe in or are you changing your toe to 1/8 toe in? What is your current rear toe? |
06-12-2020, 11:35 AM | #9 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
06-14-2020, 09:51 PM | #10 | |
1/8" toe in is quite different of what others are using on the ZL1 1LE. GM specs .1 degrees of toe in. .1 degrees is .047" 1/8" (.125") converted to degrees is .27 degrees. What camber are you running? Lots of front negative camber will cause instability under heavy braking. 2018_chevrolet_camaro_track_prep_guide-min.pdf
02-01-2024, 12:16 PM | #11 |
Drives: Chevy Camaro ZL1 Join Date: Jan 2024
Just a test as a new member to be able to write in a thread. Hey everyone! My first American car, Chevy, Camaro and ZL1 lol and I ain't young.
02-26-2024, 02:28 PM | #12 |
Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
You can also go 1/2 settings for more tunable rear if you only move one position hole on one side (doesn’t matter which side) - (1-1, 1-2, 2-2, 2-3, 3-3)
