02-27-2021, 12:52 PM | #1 |
Drives: 2017 SS camaro Join Date: Feb 2021
More HP?
What else can I add to increase my hp? I currently have a tsp vvt3 cam, LT headers, CAI and borla axle back. Not looking to go crazy high but some where in the 600-700 range would be great
02-27-2021, 01:20 PM | #2 |
Ported LT1 intake manifold or LT2 intake manifold.
02-27-2021, 02:06 PM | #3 |
I don't think 600-700 whp is possible without forced induction. If you're not opposed to that, plenty of great choices out there, Magnuson, Whipple, Edelbrock, Procharger...
02-27-2021, 05:03 PM | #4 |
I was thinking of getting a procharger but I was told I would have to change my cam due to a loss of boost and idk how I feel about that since I love the way it sounds
02-27-2021, 05:35 PM | #5 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
600+ na is going to take more compression, a set of aftermarket heads, bigger cam than what you have and more than likely have it stroked to reach the upper end of 600hp possibly 700. Just take a look at Katech's setups or some of Prays more serious builds.
02-28-2021, 08:53 AM | #6 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
While it certainly won't get you all the way to your goal, e85 should certainly be a part of the equation.
Baby Blue
02-28-2021, 11:38 AM | #7 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
If you are chasing HP numbers going FI is the most cost effective method to get there. Don’t know your cam specs but a FI engine needs to have a FI specific cam for maximum efficiency and drivability.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
02-28-2021, 06:00 PM | #8 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
How do we get more compression with FI? We can only mill stock heads (and any aftermarket head I can find) about .015, that's only a couple CC's. (fuel injector hole clearance) I think there are going to be other clearance problems with decking the block. I know we don't want to mess with the LT1 pistons because of the DI and combustion chamber. I don't see any other options?
02-28-2021, 08:58 PM | #9 |
I’m not really tryna change my cam since I’m getting it installed right now. Maybe some time in the future but I seen some setups that’s running the D1x procharger and vvt3 cam. I’m thinking about getting that but I’m stuck doing research on meth injection, e85, fuel pumps and injectors, and pulleys. If I’m not mistaken I’ve read a few post that says if I don’t use meth injection then my engine(LT1) won’t last long being that 700hp is around the limit that engine can take stock and the meth compliments the boost. But if that’s true the D1 alone should add around 150+ hp. All those upgrades would put me at around 700. Correct me if I’m wrong but would that setup last on my engine? And if not how long would it last? And if it would last then what would be needed to support that; D1x, meth injection, fuel upgrades, e85 and pulleys? I know it’s a lot but I’m new to this and trying to get the best understanding of all these car modifications and the do’s and don’t
02-28-2021, 11:10 PM | #10 |
If you're not doing any fuel upgrades your tuner better be spot on even with meth. Honestly your best bet would have been to build your bottom end while your doing your cam and save yourself down time and labor cost since you're wanting to put down 700+.
03-01-2021, 08:35 AM | #11 | |
Fueling isn't that hard to figure out since we have discussed it in several threads over in the FI section. LT4 fuel system and Meth will support 800whp on E85. If you don't want to run meth and fuel DI only then you will need FIC +30 injectors, LPE DI pump, DSX or Cordes aux low side. Or leave your stock fuel system in place and go Crawford Port Injection. Those are 3 options for fueling a GEN 5 engine with boost and Ethanol fuels. I highly suggest using E85 or a blend of(E60) over pump gas. These engines crave octane.
2016 NFG 1SS A8
03-02-2021, 02:04 PM | #12 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Ported/milled heads, MSD IM or HiRam if you're willing to cut the hood, and e85. Then get it tuned by one of the good gen 5 LT tuners.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
