Old 02-22-2021, 01:20 PM   #15
NYblack1le
Drives: 2018 1SS 1LE
Originally Posted by RobbyBeefcake87 View Post
I think the vfn looks a lot better than the COPO and you don't lose quite as much visibility since the cowl isn't as wide.
I agree. The vfn looks sick. Only downside side is you lose the ram air effect that’s possible with the copo.
NYblack1le is offline   Reply With Quote
Old 02-23-2021, 02:00 PM   #16
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
This is true, I guess I just assumed an OTR CAI or Rotofab would be used. If going right off of the Tb/velocity stack then the COPO makes more sense.
Side note, I really hate when guys are running a Rotofab or something that doesn't get fed by the opening on the hood but are running a COPO lol.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 02-25-2021, 09:18 PM   #17
AdzyHany
Drives: 2021 camaro ss 1LE
LT1 heads have some valves issues that seem to show up when you increase spring pressure, cam lobe intensity, and RPM. I believe Pray is around 4500.00 for a fully reworked set of ported OEM castings(New valve seats, valves, valve job, porting, springs...etc). However once he is done with them they seem to perform as good if not better then aftermarket stuff and even LS7 stuff as Dan mentioned.
I am not saying you can't get away with a port and valve job with new springs and hardware. Going that route is probably ok on something mild staying under 7k rpm. But if you are considering a more aggressive H/C setup with Nitrous on top it might be something to consider. Contact GPI or Pray and tell them what you are looking to do.
Sorry my notifications are turned off. $4,500 for reworked heads to work as good or better than aftermarket? Why not just spend less and get aftermarket that work just as good as aftermarket? Lol
AdzyHany is offline   Reply With Quote
Old 02-25-2021, 09:29 PM   #18
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Might be the way to go, my stock TSP PRC ported heads failed after about 10k miles on them:
https://www.camaro6.com/forums/showthread.php?t=588550
The valve seats are supposedly weak.
cmitchell17 is offline   Reply With Quote
Old 02-25-2021, 10:09 PM   #19
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Because Prays ported reworked OEM heads outperform most aftermarket castings out of the box. You would need to have the aftermarket castings hand ported to match or best Prays OEM stuff...which is why he uses them still in most of his builds.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 02-25-2021, 10:22 PM   #20
AdzyHany
My problem is, I’m up in Canada. I can only imagine what kind of times it would take to send them out and get them back. Having a set of heads ready to swap would be much more convenient. When I started the thread, I was thinking ported OEM heads were much more cost effective but now I’m thinking it’s going to cost less for aftermarket anyway
Old 02-25-2021, 10:34 PM   #21
cmitchell17
Yeah I don't understand why it costs so much for porting stock heads, I mean unless there is more set up time that I don't know about it doesn't make sense once they've got their CNC process.
Also I think you're still going to have to wait on aftermarket castings from most companies as well since they are going to stock them as cast and have to take time in finishing them.
Old 02-26-2021, 01:01 AM   #22
AdzyHany
I’m not in a huge rush to get it done but I want take collect all the parts and do it at once with the car out of commission for the least amount of time. Either way, if porting or aftermarket is going to cost “the same” I’ll just get aftermarket and sell my oem heads once I’m done
Old 02-26-2021, 07:37 AM   #23
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
It isn't just the (hand) porting, it's everything else. The new valve guides, new valves (you ever price custom made titanium intake and exhaust valves?), the valve job, etc.
IIRC, Brett told me that he makes almost the same profit on the stage 1 heads as his stage 4.
If time is any sort of issue for you, I wouldn't look into Pray ported factory castings. Last I heard, he was around a 9 month wait time on heads. and I think at that point, he just stopped taking new orders (for heads) in.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 02-26-2021, 09:19 AM   #24
cmitchell17
Apparently TSP heads they don't touch the guides or seats so it looks like its $1000 for them to fixture them up, run the CNC, maybe pressure test them (I hope) then put some springs on. I haven't been able to confirm that they do anything else to them. And I'm not talking about hand ported stuff, I can see why that cost an astronomical amount, but then again I could see where you would have to be charging a lot if you had to make a bunch of payments on all these brand new shiny CNC machines that were just sitting there doing nothing because you can't get raw material.
I think all these aftermarket parts are never really worth as much money as people pay for them, but as long as people are buying the price will just keep going up.
Old 02-26-2021, 09:22 AM   #25
KingLT1
KingLT1's Avatar
Basic port work doesn't cost that much...which is what you get with TSP oem port program along with upgraded springs.
Prays heads are completely rebuilt from the ground up. New seats, guides, valves, spring kit, and whatever stage port you opt for. As Dan mentioned a lot of cost is in using good valves and the labor to rebuild the heads. However when he is done you have a product that has been proven to best most of the aftermarket castings. What you still don't get with OEM is a thicker deck like aftermarket which may be more important on a FI build. Again as Dan mentioned Brett is back logged on orders. You likely wouldn't see anything from him until next year. You might look at Frankenstein or Advanced Inductions for OEM porting or CID for a aftermarket casting.
2016 NFG 1SS A8
Old 02-26-2021, 09:26 AM   #26
danhr
BAMF SS
danhr's Avatar
Apparently TSP heads they don't touch the guides or seats so it looks like its $1000 for them to fixture them up, run the CNC, maybe pressure test them (i hope) then put some springs on. I haven't been able to confirm that they do anything else to them.
5 angle valve job and milling
get a quote, from your local machine shop, for a 5 angle (not just a single 45* cut) valve job on 16 valves and to mill the heads .030"
then go out and price how much a cnc machine is.
then do math.
Stock Longblock
Old 02-26-2021, 09:27 AM   #27
danhr
BAMF SS
danhr's Avatar
can we not talk about that? k thanks.
Stock Longblock
Old 02-26-2021, 09:29 AM   #28
KingLT1
KingLT1's Avatar
2016 NFG 1SS A8
