02-03-2021, 02:52 PM | #1 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Mobil 1 15w50
Looking for anyone have experience useing this oil with the stock ss?
02-03-2021, 03:02 PM | #2 |
why would you use 15w50 in your ss? i use 5w40 year round and i also track my car
02-03-2021, 07:22 PM | #3 |
Well after it sized a rod bering with no damage or sighs of deto on the pistons. Then looking at the other berrings like the cam berrings Im thinking it needs a little more protection than the 0w40. Car is boosted makeing 650 maybe a little more.
02-03-2021, 09:06 PM | #4 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
What the...
This thread went sideways fast. I am a bone stock 5-30/0-40 guy. No help there but I know there are a lot of folks here that are heavily modified so you might try one of the sub forums below. Like the boosted section |
02-04-2021, 01:04 AM | #5 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
I'm not boosted but highly modified N/A and I run either Valvoline VR1 10w30 full synthetic or AMSoil zrod 10w30.
02-04-2021, 10:17 AM | #6 | |
Moving from 5w-30/0w-40 to 15w-50 sounds like a big move to me. Assuming you start this car in the Tennessee cold, that 15w at cold start might be a problem. Warmed up, you are going to be running higher pressure. Then you need to worry about the bypass pressure rating for your filter. You don't want to blow by the stock filter's media. |
02-04-2021, 10:49 AM | #7 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
More than likely there was detonation and that's what fried your bearings. Especially on a boosted car @ 11/1.
02-04-2021, 11:51 AM | #8 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
02-04-2021, 12:07 PM | #9 | |
6.2L (LT1) Engine Change the engine oil to 0W-40 or 5W-40 that meets the dexos2 ™ specification. If this oil is not available, the following oils can be used as an alternative: Valvoline ® SYNPOWER MST 5W-40, Mobil ® 1 ESP Formula M 5W-40. See Capacities and Specifications 0 331. |
02-04-2021, 02:33 PM | #10 | |
For what it's worth, i run 0w40 for street and track
Baby Blue
02-04-2021, 04:31 PM | #11 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
@OP, since you aren't actually stock anymore you might be better off switching to a 15W-50 for track use but still running 40 on the street. Would give you more protection in the high-demand environment while not overloading the oil pump all the time in normal driving.
2017 SS 1LE.
02-04-2021, 05:29 PM | #12 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
M1 0W-40 European FS has 15W-50 anti-wear additive levels with better cold weather performance. If you don't run a catch can or if your engine is an oil burner it could cause O2 and CAT issues late in life (75 - 100K (or not)). Manufactures are pushing low SAPS oil not because it's that good for your engine they are looking out for themselves, ever since the feds mandated extended emissions warranties the levels of phosphorus, zinc and sulfated ash have been reduced. Look at any quality racing or motorcycle performance motor oils and you'll find elevated levels of the above.
02-04-2021, 07:59 PM | #13 |
Oil weight likely wasn't the cause of your failure as I mentioned in another thread you started. The fact is many over think oil these days. Run whatever weight that tickles your taint in full synthetic and change it regularly. If your engine blows up it likely wasn't the oils fault.
2016 NFG 1SS A8
02-04-2021, 08:06 PM | #14 |
Doesn't Chevy call for 15W50 at the track
'20 ZL1 1LE A10,
