Old 01-25-2021, 04:28 PM   #1
legendary70
Drives: 2017 Camaro
Go Pro 9...
Hello all.
I just got a go pro 9. I am mainly going to use it on a camera arm suctioned to the outside of my Camaro.
What case or protective casing do yall recommend? just in case the suction fails and falls on street. thx
legendary70 is offline   Reply With Quote
Old 01-25-2021, 05:36 PM   #2
COKen
Drives: '21 Camao SS, BMW 435i, M Roadster
If you can find a spot to attach it, it would be a good idea to also add a tether so that if the suction cup fails you still have the camera attached to your car.
2021 Camaro SS Riverside Blue Metallic
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C.
COKen is offline   Reply With Quote
Old 01-25-2021, 05:44 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i use mine on my b pillar window but i have a case for it, also got a foam cover for it also but havent used it yet
Old 01-25-2021, 08:51 PM   #4
Bruizer
Drives: Chevy Camaro
RAM Mounts are excellent for holding at high speed as well as stability. I have the suction mount and it works quite well.
They have attachments for a ton of applications.
https://www.rammount.com/
Bruizer is offline   Reply With Quote
Old 02-02-2021, 02:33 AM   #5
peteric
Drives: 2016 camaro
Tow hook is a good place also to mount your GoPro.
peteric is offline   Reply With Quote
