Old 01-15-2021, 06:48 PM   #1
T Reno
Drives: 2018 ZL1
Key Fob reprogramming
SO I purchased a wrecked 2018 ZL1 without a Key or Key Fob....
Had my Dealership make me a laser cut key
Purchased a used Key Fob from a 2017 ZL1 Camaro
Now trying to reprogram the replacement used Key Fob and it will not "sync" with my car????
I can get it into the "Learn" mode but will not complete the process when I put the used Key Fob in the smaller back cup holder...
Any Ideas / Suggestions?
T Reno is offline   Reply With Quote
Old 01-15-2021, 09:34 PM   #2
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Hmmmm.... curious if the 2017 key is comparable with the 2018? Figuring the ECM’s between the 2 are different..
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 01-15-2021, 11:15 PM   #3
T Reno
Drives: 2018 ZL1
The Dealership says 2017 & 2018 are the same replacement part numbers
Old 01-16-2021, 09:50 AM   #4
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
I think the issue may be using a used fob programmed to another vehicle instead of a new, never programmed one. I never found an answer to that question, and the owner's manual is not clear on that point.
Anyone have a definitive answer to this?
17rsvert is offline   Reply With Quote
