01-15-2021, 10:16 AM | #29 |
The infotainment system is awesome when working as it should, especially the voice to text. My problem which started a month ago is when I connect to a USB cord there is no media sound and my phone will say not connected. I have try everything and anything but the system won't pair with my phone. Also, my infotainment system is saying unable to update. After several trips to the dealership they have discovery that the system has a bad module so I am now waiting for a replacement.
01-15-2021, 10:30 AM | #30 |
Hot Camaro
GM is actively pushing Infotainment updates across their fleet. So, while you may have gotten only an OnStar update, plenty of others are [also] getting an Infotainment update.
01-15-2021, 10:40 AM | #31 | |||
Hot Camaro
Toyota's systems are a mess. I never had more problems than what I experienced in my 2011 Tundra Platinum. Absolute garbage, but that's what you get when you create a company to build them instead of going to a company that's already good at it. Yes, FOSS can be exploited a touch more easily because the hackers can actually SEE the holes in the code instead of having to search for them. BUT... So can everyone else that codes. FOSS facilitates a much smoother, faster, and secure path to patching than closed source does. When you have a billion eyes reviewing the code instead of 20, a lot more gets uncovered and corrected very quickly. And it can get done long before the code makes into production while closed-source code has a higher risk of not getting patched until AFTER a major breach occurs. Quote:
01-15-2021, 11:02 AM | #32 |
Drives: 2017 Camaro Join Date: Feb 2020
Car Warranty advice...
Hello all.
Several years ago we purchased a buick. We also purchased the extended warranty for 3 years. I called them when the warranty was fixing to end and found out I could re-extend it for 2500. We went for it. Having said all that. I called and asked the same for my 2017 camaro. The extended warranty they offered me was 2 years. I called yesterday to ask them how much it would be to re-extend it once it was time. finance said they dont do that? he said nobody does that. I would have to buy an after market one? so having said this.....is that true? if so, what after market warranties are good and not scams and that wont break the bank? thx
01-15-2021, 12:02 PM | #33 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
Yeah I am stupid i just read the provided description from my car and it says its just LTE connectivity updates and fixes for in vehicle WiFi.
01-15-2021, 08:52 PM | #34 |
Ditto this. Mine occurred Wednesday but seems to be gone now.
'20 ZL1 1LE A10,
01-16-2021, 03:22 PM | #35 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Hmmm, so I went to install the update a little bit ago and got the message in the picture. I'm not sure what's not "ideal" about my vehicle conditions. It's connected to wi fi (either home network or my phone's hot spot), although I think it's probably already downloaded it and just needs to install it. The car was off (when it's running it won't let me update). Any ideas what needs to be different to get this update to install?
Matt Miller
2020 SS 1LE |
01-16-2021, 03:51 PM | #36 | |
Hot Camaro
01-16-2021, 05:07 PM | #37 |
Drives: 2020 Camaro RS Join Date: Oct 2019
I had this pushed OTA to my truck on January 13th and it applies to the Camaro also.
https://static.nhtsa.gov/odi/tsbs/20...81722-9999.pdf Technical Service Bulletin: #20-NA-199 Release Date: 11/9/2020 TSB #20-NA-199 Applies To These 2020 Model Year Vehicles
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic Last edited by RWT; 01-16-2021 at 05:25 PM. Reason: Add Photos |
01-16-2021, 06:01 PM | #38 | |
ETA: I've seen a couple hints that the outside temp may be too low to do the installation right now. I guess it worries about the battery? It was in the mid-30s today and not sunny at all. We have a couple days in the 40s with sun coming up, so maybe it'll work then.
Matt Miller
2020 SS 1LE Last edited by Msquared; 01-16-2021 at 06:45 PM. |
01-16-2021, 10:29 PM | #39 |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Maybe it'll get rid of my no satellite connection i keep getting, in a parking lot, street, highway!!!
01-17-2021, 08:44 AM | #40 | |
Hot Camaro
The status of several vehicle systems and factors are checked before starting installation. If your vehicle does not meet the necessary conditions (for example, if your battery state of charge is too low or if low ambient temperatures present a risk to your vehicle battery), you may receive a message stating that vehicle conditions are not ideal and the system will try again at a later time. You could try connecting the car battery to a maintainer to ensure it's completely topped off and then trying again... You could also try DISCONNECTING the hotspot and letting the car use its own LTE radios to connect and download the software. |
01-17-2021, 11:57 AM | #41 |
I'm pretty sure it's just the temps. Tomorrow, when the high is supposed to be 41F, I'll slow-charge for a while and then try again. If that doesn't work, I think we'll have 50F on Thursday.
Matt Miller
2020 SS 1LE |
01-17-2021, 01:42 PM | #42 |
I meant to ask earlier: this is a two-step update process, where first it downloads and then it updates. Is there any way to verify that it's already downloaded the update and now just has to update?
Matt Miller
2020 SS 1LE |
