09-14-2020, 10:56 AM | #1 |
Red
Drives: 2018 Mosaic Black 2ss M6 Join Date: May 2012
MSD help!
After having an MSD intake manifold ported and installed, it developed a vacuum leak somewhere which I found was common with these things. So, I pulled out the instructions and went to tighten things down. I'm not sure if I screwed it up or if the hardware was wrong. One of the bolts on the top of the intake stripped the threads after a few turns. It kind of looked like the bolt slipped through the threads once it got down deep enough. As far as replacing the threads, I'm not sure that could be done. Thought of maybe retapping them and going to a slightly bigger bolt? Anybody else ran into this? Google yielded very few results. Some c6 vette guys had similar issues but never posted a real solution except one getting a replacement manifold from msd. I don't think that's an option for me, considering I may be the one who broke it. I guess what I'm wanting to know is if I'm going to have to buy a new manifold with the cam kit I just ordered. I'm just going to give up wrenching. I rarely have the time these days and I usually end up breaking something when I try. Lol.
Stock. For now... |
09-14-2020, 11:45 AM | #2 |
Drives: like an old lady Join Date: Jun 2012
the tq for those bolts is...75 inch lb i believe. i can't imagine the threaded insert is made to withstand much abuse. do you have any pics? have you taken it apart?
09-14-2020, 11:55 AM | #3 | |
Red
I haven't taken the manifold apart and I probably won't myself. I don't really have the time but I thought retorquing a few bolts should be no problem. I'll most likely just let the shop installing my cam and heads clean up my mess in exchange for a few doll hairs.
Stock. For now... |
09-14-2020, 12:21 PM | #4 |
Drives: 2019 SS Join Date: Apr 2020
Shit can it and get an LT2 manifold, or contact the manufacturer, they might help you if you ask, doesn't hurt to try/
09-14-2020, 12:31 PM | #5 | |
Red
The shop that installed it is going to fix it when they do cam and heads in December. I don't really drive the car much at all, so it'll be fine until then. I just won't beat on it.
Stock. For now... |
09-15-2020, 08:36 PM | #6 |
Drives: 2017 Camaro SS Convertible Join Date: Jul 2019
I would be double thinking about allowing that shop to touch the car again. If they messed up a simple intake job can only worry what they will do with the complex cam and head install.
09-16-2020, 07:28 PM | #7 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
I believe the instructions were to re torque twice at Set intervals was that accomplished?
02-24-2021, 07:14 AM | #8 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
My MSD also developed a leak. The design leaves a little to be desired. The manifold has two basic pieces-the top and bottom, which are sealed by a rubber gasket and held together by relatively small allen head bolts. The design is flawed in this way: the bolts are not evenly spaced around the manifold-there is a big gap at the rear. I have highlighted the problem area in red; this is where my intake manifold was leaking. It seems as though MSD is relying on the bolts that secure the manifold to the engine to compress and seal that area.
I sealed the leak using RTV silicon, which I applied all of the way around the gasket. Another problem spot is the throttle body area-the gasket does not want to stay in the corners, it wants to pop out. The reason that I discovered the leak is that my fuel trims at idle were + 30 percent and I spent a good deal of time trying to tune the fuel at idle to correct the problem. After removing and resealing the intake manifold my fuel trims at idle dropped to -4 percent. A 34 percent switch. Just an FYI for those running this intake manifold.
Bolt-ons.
02-24-2021, 02:02 PM | #9 |
Drives: SS 6 speed of course Join Date: Jan 2016
you can order the 3 center pedestals from MSD, they are replaceable. Mine were shiznet the fist time out of the box. I believe I tapped the inserts to 1 size larger screws and never looked back, I don't mess with the inch pound torque (unless you have a snapon digital 1/4 torque wrench, actually I still have an old bar beam 1/4 one that works well enough), I now hand tighten them and have not had a problem again. So IMO the problem is the top screws are just too thin for the brass inserts at spec torque. There is LOTS of room, I have no idea why MSD went with such a thin screw and a brass insert.
