12-06-2019, 05:14 PM | #1 |
ZYJ
Drives: 2017 1SS Camaro/6 speed Join Date: Sep 2014
Can I run this tire/wheel setup? 285/35/20 and 305/35/20
Hello everyone
I have a 2017 1SS M6 with no MRC, making around 540whp. Currently lowered with Eibach pro spring. Running without any spacers/rubbing etc. 20x10.0 is +23mm (Front) with 285/30/20 20x11.0 is +43mm (Rear) with 305/30/20 Want to upgrade my next tire sizes to: 285/35/20 305/35/20 Anyone run this setup? any issue with rubbing? do i need spacers? etc will you guys recommend keep running my current size or go to 35? thank you for your help! |
12-06-2019, 07:19 PM | #2 |
Drives: 2017 Mosaic Black 2SS Join Date: Jul 2013
You should be good. I'm running them sizes on the same springs on MMR 228s now and have no rubbing issues. I just had to move the piece in the rear wheel well.
12-06-2019, 07:33 PM | #3 |
This thread needs pics...
12-07-2019, 12:32 PM | #4 |
ZYJ
12-13-2019, 09:33 AM | #5 |
Drives: 17 Camaro lt, 22 Camaro LT1 Join Date: Nov 2016
I have a set of Cooper RS3 305-35r20 on the rear and 275-35r20's on the front. I've run both 30 and 35's on the rear and can say its better to use the 30's. Fronts have plenty of room but the rears like to rub with a full tank of gas or any additional weight in the back. It's livable and I intend to use up this set up on the car. Also, not lowered and no mag ride.
12-18-2019, 10:32 AM | #6 |
Red Hot SS
Drives: 2017 Camaro 2SS Join Date: Nov 2013
If your tires wouldn't stick past the fender well you would not be rubbing.
01-01-2020, 12:59 PM | #7 |
Drives: 2016 Camaro SS Join Date: Sep 2019
Does anyone with MRC run 305/35/20 ,if so do you have any rubbing?
This is with stock Camaro SS 2016 20 inch rims, if they fit did you need to move the harness. Last edited by Black16; 01-01-2020 at 06:28 PM. |
01-01-2020, 04:02 PM | #8 |
Red Hot SS
What width wheels are you running and what are the offsets?
