03-15-2016, 08:08 PM | #1 |
Drives: 2015 Camaro Z28, 1974 Turbo Nova Join Date: Feb 2016
How to remove existing tint
03-15-2016, 09:27 PM | #2 |
IkoIko
Hi SS-E-Ya,
If you have a tea kettle, bring it to a boil and hold the lens over the steam. The glue should release, but it takes patience. I've used this technique to remove stickers from plastic. After the film releases some Goof Off on a soft cloth should finish the piece to a smooth surface. |
03-15-2016, 09:31 PM | #3 |
Straight ammonia, let it soak in it, check it every 20 minutes are so until the adhesive lets loose, and it will sooner are later.
Heat will help if you have a way of warming it while you are soaking it.
JRE 750 HP package
Rag Top Rob |
03-16-2016, 09:34 AM | #4 |
It's paint. Not vinyl.
03-16-2016, 01:44 PM | #5 |
Drives: 2010 2SS Camaro 6sp. Join Date: Jan 2012
Your title threw me off. So its just paint to tint it. I would Recommend goof off. Alittle bit at a time.
03-16-2016, 01:46 PM | #6 |
P.S. Dont heat it up at all and no steam. You could try warm water with dish soap first. Use a sponge.
03-16-2016, 02:46 PM | #7 |
Tried goof off, no luck. Tried wet sanding with 1000 and 2000 grit, still no luck.
03-16-2016, 03:46 PM | #8 |
Is it possiable that it was already sanded and that is why its darker? Are you the first owner of the car.
03-16-2016, 04:05 PM | #9 |
03-16-2016, 04:24 PM | #10 |
This is a bit stronger than goof off. http://m.homedepot.com/p/Klean-Strip...VM46/100122813
Paint thinner might be to strong but this dries quick.
03-16-2016, 06:03 PM | #11 |
Drives: 2014 2SS/RS/1LE Join Date: Nov 2015
03-17-2016, 01:17 AM | #12 |
Drives: 2015 Camaro 1SS/RS 1LE Join Date: Apr 2009
Is that tint rubbery feeling? I ask because that looks a lot like smoke Plasti-Dip. If so, Goo Gone will dissolve it. If it's paint though, most thinners will not play nice with the plastic lens. You'd either need to be more aggressive with sanding or just buy new ones, but I'm guessing you have other, more expensive lights with that tint on there as well...
03-17-2016, 08:20 AM | #13 | |
03-17-2016, 08:21 AM | #14 |
