Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 03-08-2016, 08:49 PM   #1
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Front bumper fascia removal
I will be doing the illuminated bowtie and other things tomorrow so I will be removing the front bumper fascia and will post pictures so others will know what to do if they need to remove it for some reason. Stay tuned
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 03-08-2016, 09:09 PM   #2
BadBillyJack
Drives: 2016 2SS Camaro
Maybe this will help you a little bit.
Front Bumper Fascia Replacement
Removal Procedure
1. Front Wheelhouse Liner Replacement » Remove
2. Front Bumper Fascia Upper Molding Replacement
3. Front Compartment Air Deflector Replacement
https://gsi.ext.gm.com/image_en_us/g...93/4193033.gif
4. Front Bumper Fascia Outer Bracket Bolt  (1) » Remove [4x]
https://gsi.ext.gm.com/image_en_us/g...93/4193087.gif
5. Front Bumper Fascia Bolt  (1) » Remove
https://gsi.ext.gm.com/image_en_us/g...93/4193090.gif
6. Front Bumper Fascia Upper Bolt  (1) » Remove [2x]
https://gsi.ext.gm.com/image_en_us/g...93/4193097.gif
7. Carefully push a small nylon wedge between the fascia (1) and the fascia guide. Insert a small flat-bladed tool into the fascia slot and depress the snaps one at a time and pull on the fascia at the same time to gradually remove the fascia.
8. Disconnect all electrical connectors.
2016 2SS Nightfall, A8, NPP, MRC, Jet Black leather.
Originally Posted by 20171LE View Post
The fact remains, the Camaro designers have another fail in not transferring the clothes hanger from the ATS to the Camaro.
I, and every other Camaro owner that hangs clothes in their cars, need a solution.
BadBillyJack is offline   Reply With Quote
Old 03-08-2016, 09:14 PM   #3
BadBillyJack
I just looked at the body emblem package installation procedure for the first time. Pretty cool they just use an inline harness that goes in between the passenger side DRL and connector.
Old 03-08-2016, 09:28 PM   #4
Hyper1SS
Hyper1SS's Avatar
Removal Procedure
Thank you! I figured it was pretty much the same Volt locations as the 5th Gen. I had it off both of mine several times.
Order ID: TDHQMS
Old 03-09-2016, 05:44 AM   #5
TigerCamaro
Drives: 2SS, Mosaic Black, Ordered
The front fascia is only held on by those bolts through the wheel well and the top? There is nothing underneath? Doesn't sound too hard except for the fact that it is pretty big to handle. I am assuming a two man job.
2SS, Mosiac Black, Adrenaline Red, A8, MRC, NPP, Sunroof, Nav, Silver split spoke
Ordered 12/28/15
1100 1/11/16 2000 1/26/16 2500 1/27/16
3000 1/28/16 3300 1/29/16 TPW 2/15/16
3400 2/4/16 3800 2/15-16 BUILT!!!
4300 2/17 4200 2/23 4800 2/26 6000 3/5/16!!!
2015 Silverado LTZ
2011 Escalade
2006 Honda Accord
1988 IROC Z Camaro (sort of dead)
TigerCamaro is offline   Reply With Quote
Old 03-09-2016, 01:13 PM   #6
Hyper1SS
Hyper1SS's Avatar
The pictures and links up above are wrong. If you do not remove the screws from the bottom lip it will all come off in one piece. In that case you would have to remove the 4 silver bolts in the underbelly pan.
Order ID: TDHQMS
Old 03-09-2016, 01:21 PM   #7
Hyper1SS
Hyper1SS's Avatar
I started by taking the screws (circled) that hold the bumper cover to the black radiator cover.
Order ID: TDHQMS
Old 03-09-2016, 01:29 PM   #8
Hyper1SS
Hyper1SS's Avatar
Next I removed the screws under the front lip (Circled) and the ones that hold the 2 small rubber airdam pieces on. The yellow circle you don't remove which is a rivet the holds a bracket onto the bumper cover.
Order ID: TDHQMS
Old 03-09-2016, 01:34 PM   #9
Hyper1SS
Hyper1SS's Avatar
Next remove the screws in the wheel well from the carpet liners. The 5th screw is directly above the wheel. I removed 5.
Order ID: TDHQMS
Old 03-09-2016, 01:38 PM   #10
Hyper1SS
Hyper1SS's Avatar
Now time to remove the 4 screws the connect the front bumper to the fender. the 4th screw is at the very top of the bumper cover. I got to it with a long extension and ratchet behind the hood shock.
Order ID: TDHQMS
Old 03-09-2016, 01:42 PM   #11
Hyper1SS
Hyper1SS's Avatar
Next remove the screw from the black plastic bracket near the side marker and loosen the other 2 screws in the bracket but do not remove them. The front screw closes to you remove. The very back one I had to you a swivel and a extension to get to it.
Order ID: TDHQMS
Old 03-09-2016, 01:49 PM   #12
Hyper1SS
Hyper1SS's Avatar
There is only 1 connector you have to unplug before removing the bumper and it is on the drivers side above the LED light stripe silver ballast.
Order ID: TDHQMS
Old 03-09-2016, 01:50 PM   #13
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
anyone know what the little metal electronics module thing is there in those pics. I noticed it when taking pics of where the airbox snorkel leads to but couldn't make out any identifying writing.
EDIT: nevermind. Appears to be the HID ballast.
Old 03-09-2016, 01:56 PM   #14
Hyper1SS
Hyper1SS's Avatar
I sit a box underneath the front lip of the front bumper so when I removed the last fender screw it did not slid and fall. I done this by myself so it can be done with 1 person. Here are the last pictures removed.
Order ID: TDHQMS
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
