06-07-2020, 09:19 PM | #1 |
Drives: 2014 Camaro SS 1LE Join Date: Oct 2019
DAMN-Important?
So I did a differential fluid change.
The lil rubber washer must’ve fallen out during cleaning. Of course it’s the drain plug. Will it leak? OK to leave it out till next change? ALSO The plugs had a decent amount of magnetized dust. No metal pieces just a thick amount of goop. That NORMAL? Its last pic |
06-07-2020, 10:34 PM | #2 |
Very normal on the goop
An Rock Auto has drain plug with new gasket. https://www.rockauto.com/en/catalog/...ain+plug,12285
Orange Krush II
06-07-2020, 10:54 PM | #3 | |
I’ve already installed my original AND Filled with fluid. Will there be a leak issue? |
06-08-2020, 12:20 AM | #4 |
Stigs Bahraini Cousin
Well, i never replace any drain plug lol.
not only the camaro, any car i've ever owned and never leaked.
2015 CAMARO 1LE
06-08-2020, 01:23 AM | #5 |
You don't need a new gasket or crush washer.
Teflon tape the threads, or spin the threads in some gasket maker. If you use a gasket maker, let it set before putting the gear oil in. I just did mine, and I actually reused the washers, but wrapped the threads in Teflon tape. NO LEAKS. I had a 2003 Silverado, the oil plug leaked. I just spin the threads on some sealant, wait a half hour, good to go, never leaked. Yes, you can buy new stuff, but when you pull the plug and then realize you need it, it's too late... So, that worked, so I just kept on doing it that way. 30 minute Gasket Maker is great! |
06-08-2020, 02:23 AM | #6 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
My take on this is you discovered the seal AFTER you installed the plug and filled diff. Yes, it may cause a nuisance leak after driving around. Clean out your drain pan, pull that drain plug and install seal. Refill with same fluid. The magnetic munge on the drain plug you previously found is normal.
06-12-2020, 12:32 PM | #7 | |
06-12-2020, 04:01 PM | #8 |
06-12-2020, 04:06 PM | #9 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I know that you said you found the washer AFTER, but just for future reference, and if this happens to anyone else, the top and bottom plugs are the same Part #.
You could have just put the one with the washer as the drain plug, then ordered a new one for the fill and replaced it without losing much.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
06-12-2020, 07:04 PM | #10 | |
position to make that conscience decision. You knowledge that in the first sentence, then make that statement in the 2nd, like he knew the washer was missing before installing the drain plug, to use the washer from the top plug. Can't have it both ways. |
06-13-2020, 08:01 AM | #11 | |
Because he had the picture of them both out, I assumed he noticed it was missing then, but wanted to put them back as they came out. My apologies for not noticing that he noticed after they were reinstalled. I read it as he knew it was missing but only found it after it was all put back together.
06-13-2020, 11:06 AM | #12 | |
I’ll save the rubber washer for next change. May come sooner as I may add a rear differential cooler. |
