03-16-2019, 11:05 AM | #1 |
Drives: 2019 Shadow Gray Metallic ZL1 Join Date: Jan 2019
Our stock 2019 A10 dyno results.
Finally got enough miles on it to open it up
The results were a best of 554hp 598tq. Now time to start adding mods https://youtu.be/0Y6Q4XCcYx4 Last edited by Bain; 03-16-2019 at 12:02 PM. |
03-16-2019, 11:10 AM | #2 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Damn, it goes pig rich under load.... No wonder there are good gains with just tuning.
03-16-2019, 11:19 AM | #3 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Apr 2014
03-16-2019, 01:34 PM | #4 |
Drives: 2018 ZL1 A10 Join Date: Feb 2019
Those are good stock numbers . . . Healthy
03-16-2019, 01:53 PM | #5 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
03-16-2019, 03:00 PM | #6 |
Drives: Gen V Viper GTS Join Date: Jan 2018
You should ask for SAE corrected Dyno numbers as those are the most realistic. STD #s overstate power.
03-16-2019, 03:17 PM | #7 |
Drives: 18'-1LE Join Date: Jul 2017
Impressive torque number.
03-16-2019, 03:27 PM | #8 |
Drives: '19 2SS M6. Join Date: Aug 2018
What’s with the drop off after about 6k and up. Is that normal ?
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
03-16-2019, 04:33 PM | #9 | |
Probably this was due to the gear it was in, mine also did this, on the first dyno pulls because it was in 6th gear. 1:1 is the 7th gear, I bet that was the issue.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
03-16-2019, 06:14 PM | #10 |
03-16-2019, 06:51 PM | #11 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Got to protect those cats for 8 yrs or 80,000 miles.
03-16-2019, 08:10 PM | #12 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Even running 100% E85 on my 3576R Evo X, I preferred to keep AFR under 12 for track duty. I was running 26-27 PSI peak though, much higher than ZL1 boost. |
03-16-2019, 11:25 PM | #13 |
Drives: ZL1/335i Join Date: Apr 2014
I think some of you guys are confusing the recommended AFR of direct injection engines with port injected engines. DI engines run quite a bit leaner than port injection in most cases.
A lot of reputable tuners run these LT4s as lean as .85 lambda. As much as I hate using AFR to describe this stuff as it’s confusing and often inaccurate (it varies a lot based on ethanol content; lambda doesn’t), .85 lambda is about 12.47:1 on straight gasoline. I run mine at .80-.81 (11.75-11.9 ish, and that’s considered on the rich side. I’d go leaner if we didn’t have crap gas out here. So yes, this is normal for a stock ZL1, but also quite rich. Mine was pretty much identical stock. It’s this rich condition that myself and many other tuners have pegged as the biggest issue with the factory tune file. It seems to over-report airflow, which makes it run rich as well as limit torque output more than it should. Correcting the airflow model helps a ton. |
03-17-2019, 12:15 AM | #14 |
