Old 08-07-2013, 02:27 PM   #1
TrackZero
TrackZero's Avatar
Drives: 2010 Camaro SS
Question Question for anyone who has done a cam already
I am reading that I need to torque my old crank bolt down to 240 lb ft, did everyone do this? If so I can get a new torque wrench and I am guessing a MASSIVE pipe to use with it. Just curious what everyone else is actually doing.
2010 IOM SS - CAI, VMAX ported Throttlebody, ARH Longtubes to tailpipe Yank 3600SS Torque Converter, GPI SS4 VVT cam, Custom tune by Rhino79
TrackZero is offline   Reply With Quote
Old 08-07-2013, 02:31 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The arp bolt torques that tight, the factory is 37 ft/lb plus 140* of rotation.
Don't use old bolt to pull pulley back on with, use an installer.
Do use the old bolt to fully seat the pulley, prior to new bolt installation and tq.
Here is a good article on pulley swap how to:
http://www.planetlsx.com/tech/How_To..._Camaro_SS/105
Rhino79 is offline   Reply With Quote
Old 08-07-2013, 03:15 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Something like this, this is what I have and has worked great.
http://www.ws6project.com/user_stor/...k-pulley-bolt/
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 08-07-2013, 03:19 PM   #4
TrackZero
TrackZero's Avatar
I was able to find a longer bolt to put the pulley on, I am more just curious if the 240lb ft is indeed needed. It sounds like it is, so I will have to buy a new torque wrench.
Thanks for the replys.
Old 08-07-2013, 04:25 PM   #5
Rhino79
Rhino79's Avatar
I use a big F ing impact with old bolt to seat pully. Then tq new bolt
Old 08-07-2013, 10:13 PM   #6
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
^^ what we did too!
Camarojt is offline   Reply With Quote
Old 08-07-2013, 10:21 PM   #7
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
I thought impact was bad?
Nightmare2012 is offline   Reply With Quote
Old 08-16-2013, 02:47 PM   #8
TrackZero
TrackZero's Avatar
Well guys, I have another question for you.
Well, I am running into an issue. I can't seem to get decent ptv clearance. bought an additional lifter(HL124) and filled it with washers to make a "solid" lifter for testing. I filled it to the point that I can just get the retaining clip back into the lifter. I used this as my inspiration. http://www.camaroz28.com/forums/lt1-...urposes-623939
I am working on a piston that has a .04" flycut in it. When I use clay, it seems to chop the clay off, implying to me that there is no clearance. After trying this about 4 times, and not getting a result I liked. I rigged up the dial indicator to sit on the tip of the rocker are, on top of the valve, then measuring how much additional I can push the valve down. At one point in the rotation, it seems like I cannot push it down any further than the cam is lifting, implying again that I am basically touching the pistons.
Do you have any thoughts on what could be going wrong here? I can't imagine I have that much clearance difference than rhino has on his car.
Old 08-17-2013, 01:08 AM   #9
TrackZero
TrackZero's Avatar
Well turns out I wasn't checking at zero lash
Old 08-17-2013, 09:00 AM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I have 2 of those lifters YOU SHOULD OF came in here I could of shipped them out to ya man!! Lol
Glad your back on it! Keeps us better posted from now on.
Old 08-17-2013, 09:12 AM   #11
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
It certainly can be! I have seen some people trash their crank threads doing it that way, but as with everything... YMMV! I would say that if you get enough threads in before you start knocking on it with an impact gun you'll probably be just fine.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
