05-18-2013, 12:40 PM | #1 |
RX catch can, not working?
I just went to change my oil, and drain the catch can. About 2 drops of oil came out, had anyone else experienced this? Am I lucky because my car doesn't suck much oil, or stupid because I have it installed wrong? Any thoughts are appreciated.
Thanks Sent from my SCH-I535 using Tapatalk 2
2010 IOM SS - CAI, VMAX ported Throttlebody, ARH Longtubes to tailpipe Yank 3600SS Torque Converter, GPI SS4 VVT cam, Custom tune by Rhino79
05-18-2013, 12:58 PM | #2 | |
Drives: none (yet) Join Date: Jul 2012
05-18-2013, 01:06 PM | #3 |
I think it is correct. The top center goes to the back of the driver side, and the outer connects just under the throttle body.
05-18-2013, 01:06 PM | #4 | |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
There's been a few people who had the incorrect routing of their hoses for thousands of miles and finally figured out it was configured wrong.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
05-18-2013, 01:13 PM | #5 |
Well I just went back out and apparently everything is fine. I expected it to flee much freer and sooner,I ably waited about 4 minutes originally. After leaving it draining for about 30 minutes, there is this brown sludge.
So now what do you guys do about the sludge still in the hose when you close the valve? I don't want that "spraying" the undercarriage while I drive. Sent from my SCH-I535 using Tapatalk 2
05-18-2013, 01:13 PM | #6 |
Also thanks for the quick replys!
05-18-2013, 01:24 PM | #7 |
Drives: 2SS/RS Join Date: Sep 2008
Personally I took the hose off as I didn't like the way it looked. Plus its easier for me to reach under the can and catch the oil than it is to put the hose into something and open the can.
How many miles are we talking about here? If it's less then 1k then I wouldn't worry about it as your can shouldn't have much. If it's 4-5k or more then something is wrong. |
05-18-2013, 01:25 PM | #8 | |
05-18-2013, 01:55 PM | #9 |
NEC5 C-HOLE CHAMP
Drives: 2013 camaro 2SS/RS 1LE 1 of 221 Join Date: Jan 2011
negative on that i can email you an easy to read schematic ..do you have the dual catchcan and ae you venting both sides of the crank
05-18-2013, 02:51 PM | #10 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Center of the can on a V8 runs to the rear of the drivers side valve cover (L99), or to the valley cover vent (LS3) below the TB. Outer valve runs to the vacuum barb on the passenger side of the intake manifold snout:
If you dont like the drain hose, just cut it off so only an inch or so is left. The hose is long so it can be either hung down beneath the car to drain when oil is changed, or cut to any length the customer desires. |
