10-24-2012, 11:27 PM | #15 | |
Drives: 2015 2LT Torch Red C7 Stingray Join Date: Jul 2012
Was the car pulling on you or vibrating? |
10-25-2012, 12:27 AM | #16 |
Yeah lately the car stated feeling like it would pull randomly. A little vibration but not allot. I assumed it was the front tires.
Both rear tires look pretty much the same, which leads me to think the alignment was wrong, as opposed to slipped out of alignment. I am going to dig up the alignment sheet I got in April. I will post a shot of that as will as the one I get Friday. I still cannot believe how bad it is, and both front and rear are worn on the inside, the outside of the tires looks fine.
2010 IOM SS - CAI, VMAX ported Throttlebody, ARH Longtubes to tailpipe Yank 3600SS Torque Converter, GPI SS4 VVT cam, Custom tune by Rhino79
10-25-2012, 11:41 PM | #17 |
Here is my alignment sheet. Guess it was only about 6000 miles since I got them done
I am going in tomorrow for another alignment.I will post that sheet as well
10-25-2012, 11:47 PM | #18 |
Drives: nothing Join Date: Nov 2010
These are mine after 5k miles. I DO peel out.
10-25-2012, 11:53 PM | #19 |
Lets compare your sheet vs. the following:
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars] |
10-25-2012, 11:59 PM | #20 |
They do not seem to far of to me, but I am no expert. I am really curios to see if they have somehow moved further off.
10-26-2012, 12:10 AM | #21 |
I am no alignment expert either. Your front camber on the right side was a 0.7 difference though, I am not sure if that's a really bad thing or not.
10-26-2012, 05:06 PM | #22 |
Well it looks like some how the total toe on the rear got way out of alignment.
Not sure how to avoid this in the future,I avoid put holes and pumps like the plague.
10-26-2012, 06:34 PM | #23 |
Drives: His Wife Crazy Join Date: Jan 2008
It was not anything that you did, don't be concerned about how you drive.
It is interesting that is was not one wheel, but instead it was two equally out. That kind of thing doesn't happen. Glad that you have it sorted out now, |
