Old 01-28-2021, 11:21 PM   #1
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
SC3R tire age: how old is too old?
I just bought a set of four Goodyear SC3R’s but foolishly did not check the date before paying for them, turns out they were made in the 18th week of 2018 which is older than the tires I was tracking with last summer.
Is there any rule of thumb or standard agreed-upon rate for how Much a tire degrades performance wise per year? Assuming of course it was maintained properly in a heated storage facility?
Would there be a significant drop off a performance between an SC3R that is one year versus two years versus three years old?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 01-29-2021, 07:34 AM   #2
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I'll put money on you won't notice any performance drop and they definitely won't be dangerous. Unless the old owner stored them outside in the sun and snow haha. If they were stored properly they will be fine. Also if you got a good deal and they are a half second slower, who cares? It's still a good buy for track rubber.
Old Ride: 2016 Callaway SC630 Camaro SS
Old 01-29-2021, 08:01 AM   #3
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
I've heard the 4 year mark is when you can notice a difference. Haven't done much research on it though. Usually only last a few months for me and I've never received tires older than 2 years.
ZRacerLE is offline   Reply With Quote
Old 01-29-2021, 08:13 AM   #4
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I had new 3017 fronts and 3917 rears on recently - new old stock properly stored in HVAC controlled garage. As grippy as ones from 2020. Improperly stored tires, like out in freezing cold or blazing hot garage worries me more regardless of date code.
RUQWIKR is offline   Reply With Quote
Old 01-29-2021, 11:34 AM   #5
GunMetalGrey
OK good to know, thanks guys, a former racer also told me the four year mark is where he draws the line
And yes they were a slightly better deal than the price tirerack sells them for, but only about $50 a tire less
Old 01-30-2021, 08:33 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
a friend of mine purchased brand new 3Rs from Tire Rack in November 2020 and they all had a 2018 DOT date on them. They will be fine.
Old 02-02-2021, 02:45 PM   #7
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Been using Tire Racks old stock whenever I can and they work great
carguy55 is online now   Reply With Quote
Old 02-04-2021, 04:30 PM   #8
GunMetalGrey
The tire shop actually let me return them, full refund, great customer service!
I called TireRack and Nate (they are on commission) said that the stock ZL1 1LE sized SC3R's they've sent our recently have MFD of 2019 for the rears and 2020 for the fronts.
I'm going to purchase from them in March/April once I'm closer to needing them and the temperature increases so they can't freeze during transport.
Old 02-04-2021, 04:36 PM   #9
ZRacerLE
ZRacerLE's Avatar
Nice!
Old 02-08-2021, 08:25 PM   #10
rickybobby
Drives: BMW M3, ZL1 1LE
I used a set of the or stock 3R’s from tirerack and hated them. They were way off pace and had terrible breakaway characteristics. I’ve been through many sets of them so have a good reference point. I would be ok with a slower tire, but the handling traits weren’t worth the savings to me.
rickybobby is offline   Reply With Quote
Old 02-08-2021, 09:23 PM   #11
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
2 years of autox and 20+ heatcycles, too old. Now properly stored... maybe not as accelerated.
ing for grip.
http://www.motorsportsne.com/
Old 06-18-2022, 03:33 PM   #12
GunMetalGrey
Just tracked with a set of slightly used four year old SC3R tires, they worked great… they were stored out of the sun and out of the cold
Old 06-19-2022, 07:14 AM   #13
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
2017s used in 2022 - worked like new. Stored in garage
Zl1+911 is offline   Reply With Quote
