10-18-2020, 03:04 PM | #1 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Lost bolt for securing M6 transmission cooler line
Hi everyone, yesterday I did a manual transmission fluid flush on my ZLE. To fit a ratchet onto the fill plug, you have to unclip the the transmission cooler line to get enough clearance, or unbolt the retaining bracket from the transmission. I did the latter.
Unfortunately I forgot to put the bolt back and I lost it! The transmission cooler line isn't fully secured now so I don't want to drive the car much until I can get it clamped back down. Anyone know the part number for this or could tell me what size bolt it is so I can just get a replacement from my local hardware store? I was unable to locate the assembly by browsing on gmpartsdirect.com. It is pretty small, hex head, and didn't require much effort to loosen since it doesn't hold much.
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
10-25-2020, 03:37 AM | #2 |
1LE Convert
Bought some random bolts from the hardware store to try them. It's an M10 <edit: M6>, but not sure of the correct length or what grade to get.
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) Last edited by R3ctivision; 10-25-2020 at 04:36 PM. |
10-26-2020, 10:48 AM | #3 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
do you have a pic of the location?
11-01-2020, 09:12 PM | #4 |
1LE Convert
No, but it is right above the fill plug on the transmission.
11-01-2020, 09:16 PM | #5 |
1LE Convert
I can confirm that a replacement bolt M10-1 20mm does fit nicely. I got standard 10.9 class steel but maybe I should replace with something else that may have better corrosion resistance in the aluminum transmission housing.
11-01-2020, 11:15 PM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Chevy probably has it for 2 bucks. OEM bolts are always preferred...
11-02-2020, 12:40 PM | #7 |
1LE Convert
I couldn't find the part number online. I doubt the dealer stocks such a random non-consumable part but I could try.
11-02-2020, 12:48 PM | #8 |
hit up matt from wildhammer he always been good at finding oem part #s and random parts for me!
11-02-2020, 01:22 PM | #9 |
My point is these are new cars - every part is available at the dealership and currently, all very cheap since in production. It may take 48 hours for you...count yourself lucky - my last order took 6 weeks (to Germany).
I've used Superior Chevrolet in Kansas City for 15 years...Chris May figures it out every time. Ships overseas too. No trips to Ace hardware should be required.
11-02-2020, 02:12 PM | #10 |
Geoff
It appears to be Item # 6, 19352502, lists for ~ $3.50
This is for a ZL1, but they should be the same. If you're not comfortable, send me a PM with your VIN and I can verify
11-03-2020, 06:35 PM | #11 |
1LE Convert
Thank you! That looks like the part based on the drawing. I could not locate this drawing on gmpartsdirect.com.
Will PM you my VIN, thank you!
11-04-2020, 09:39 AM | #12 |
Geoff
it's the same bolt
Funny thing i did not know.........your color is called 'pull me over red' on the attributes table
11-04-2020, 05:11 PM | #13 |
Drives: blue velvet Join Date: Jul 2018
next time try to use a 2" extension. i managed to squeeze it in there without removing any lines, but it was a pretty tight fit. had to use a slim breaker bar. with a 1.75" extension you could probably use a proper torque wrench.
thank you for doing the digging and reporting back on the correct size bolt. |
Thread Tools | |
