09-02-2020, 03:59 PM | #15 | |
09-02-2020, 05:36 PM | #16 |
Drives: 2019 ZL1 A10 Black Mosaic Join Date: Nov 2018
Be wary of Katech! That is all I am going to say.
2019 Black Mosaic ZL1 A10
Kong Ported SC, 2.3 Grip Tec, Roto-Fab Big Gulp, NW103 TB, Mighty Mouse CC, ADM Expansion Tank, ARH 1 7/8 Headers, Catless 3" X-Pipe, Corsa Extreme, Eibach Springs, BMR Cradle Lockout, BMR Trailing/Control arms. |
09-04-2020, 09:10 PM | #17 | |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
So you have a thermostat and some plates that get spit out of a CNC at Katech...so a brand new oil pump design will undoubtedly be superior? Let's use your logic a different way: Katech is making a new version of a part that GM/Melling has been producing for many years. Said part is designed, tested and audited with a budget that relatively speaking, is infinitely larger than Katech's. Yet, the GM pump has has some issues in the past. But because Katech has "a tight connection with GM"...their pump will be superior to the current OEM one. Furthermore, one shouldn't question it (yet, we literally know nothing about it other than they have been saying for over a year they are working on a wet sump LT4 pump)? I have a hard time with your logic. I have nothing bad to say about Katech...I used to live a few minutes from their shop and I too like their parts...but come on! |
09-05-2020, 06:42 AM | #18 | |
A small, hardcore, company can use materials that are superior (but too expensive) for standard production. The new parts can be engineered for the kind of use and environment that racers and enthusiasts will put it through, as opposed to cheap production pieces that are designed for quiet operation, ease of factory assembly, etc. Guess there’s always a few different ways of looking at this.
09-05-2020, 10:51 AM | #19 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Is the assumption that the Katech pump will be hand assembled and “blueprinted” with tighter tolerances vs the mass produced OEM pump?
09-05-2020, 12:35 PM | #20 | ||
These often go even beyond understandable optimizations for other criteria that Josh listed. Smaller companies can very easily be tighter knit, with less flab and ego hampering the actual vision of say, quality and customer service. It does not happen automatically, but much easier to pull off with 50-250 than with 100K employees. [Just for the record, I work for a very large company and struggle with this corporate attitude all the time, trying to create a pocket of trust and excellence with my team.]
09-05-2020, 05:18 PM | #21 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
It’s my understanding for wet sump motors like our LT4, Katech takes an OEM pump and makes it better, I don’t think they CNC an all new one or create casting molds for new ones. I believe they inspect the GM part, discard any that show indications of defects, port for better flow, blueprint, etc and in this way ensure reliability and quality of the part so it’s not a weak point—it performs and lasts as originally intended. They also make HIGH FLOW dry sump LS7 versions that have CNC components added to an OEM core.
https://store.katechengines.com/gen-34-oil-pump-p5.aspx |
09-05-2020, 08:09 PM | #22 |
Drives: 2022 ZL1 1LE Join Date: Sep 2015
GM will not warranty an aftermarket oil pump. If a KT oil pump fails and an engine is lost, the very purpose of having one is lost. The only way to fix this situation seems to be with GM fixing a very shitty design pump...especially one on a 650hp motor. We'll never know how many GM pumps actually failed without litigation or government intervention.
I'm not aware of any oil pump failures from the dry sump LS7 motor. Too bad we didn't get that system.
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
09-05-2020, 09:11 PM | #23 | |
So far I haven’t heard of any failed ZLEs on track due to oil starvation from Gs only, only pump failures. Anyone know if a ZLE has failed like this? The Gs it can generate are incredible on sticky R comps. |
12-10-2020, 07:02 AM | #24 |
Drives: Turbo 6.2 Join Date: Feb 2019
Bump. I've been in contact with Katech and ordered mine a couple weeks ago. They were doing a batch of 50, shooting for late Dec/early Jan. I got on that list in spot ~40. I'll let you guys know when I hear something.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
12-30-2020, 08:59 AM | #25 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
Just a quick update for you guys.
Pumps are currently in production. We had a small delay regarding raw material availability. We're trying to ship the pre-ordered pumps by the 2nd week in January. |
12-31-2020, 10:18 AM | #26 |
Drives: 2017 ZL1, 2015 Z51 vette 2005 gto Join Date: Sep 2009
Sweet
12-31-2020, 10:57 AM | #27 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
I will be interested to see how these pumps perform! Only thing holding me back from all the performance upgrades is this oil pump failure crap! What’s the odds of total motor failure if the oil pump fails? I really want to start modding this car!
12-31-2020, 01:04 PM | #28 |
Just do the Katech oil pump when you change the cam. No brainer upgrade.
