09-19-2018, 03:12 PM | #1 |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
Anyone running "Triple X" Heat Exchangers
Like the question says, anyone using this system and have any thoughts? I mostly run the ZL1LE on a road course. I am looking at doing some mods and the builder recommended this set up. Thoughts?
19 ZL1-1LE A10
09-19-2018, 05:13 PM | #2 |
Drives: 2017 1SS 1LE Join Date: Aug 2017
Curious as well.
What kind of temps are you seeing (oil and coolant) on your car on track?
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
09-19-2018, 05:55 PM | #3 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
sub'ed
09-19-2018, 07:28 PM | #4 |
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
Weapon-X just posted this on FB and IG.
You were destined to get these!!!lol |
09-19-2018, 07:37 PM | #5 |
We deal with Weapon X and these are very effective. I don't have any road testing with them but I can attest to the cooling capabilities. A pullied LT4 usually takes hours to cool down between dyno pulls. With this heat exchanger we can really speed up the tuning process. If you guys need one contact us (forum sponsor) and we can sell you one or even install it for you if you're local.
09-19-2018, 08:46 PM | #6 | |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
The kit holds 150% more fluid and unlike most on the market, we replace all THREE heat exchangers, not just the center unit... because we understand what goes into the Manifold Air Temp calc used for timing. The days of "IAT2" are gone |
09-19-2018, 09:00 PM | #7 |
Drives: '17 ZL1 Join Date: Jul 2016
I'd like to see actual test data, not from dyno pulls. Maybe before and after air temp logs from roadcourse track days from the same track and similar outside air temperature.
09-20-2018, 08:22 AM | #8 |
This^
19 ZL1-1LE A10
02-23-2021, 11:12 AM | #9 |
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
After 2 years, still no data? Thinking about the triple threat for my 2021 ZL1 1LE, but real world test results speak most.
LPE 650+,IOM Pearl White Rallys
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
02-23-2021, 11:29 AM | #10 | |
My setup has been converted for the left aux cooler to be the C&R racing oil cooler. (I have data, but it's not a true apples-to-apples with the setup in this thread.) Couple their oil cooler with their 42mm core center heat exchanger for the supercharger, then their auxiliary water cooler for the right side, and I guarantee this setup will outperform anything on the market. Don't get me wrong. I'm not saying anything bad about Weapon X or their offerings that were made available before anyone else. The C&R Racing solution came along much later, but I believe this is now the best solution available. It comes at a price though. Their stuff is not cheap, but if you want the best available, that's what you want.
02-23-2021, 11:34 AM | #11 | |
02-23-2021, 12:38 PM | #12 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Vengeance Racing uses AFCO heat exchangers. That's what I have in my car, they seem to do a very good job.
02-23-2021, 02:48 PM | #13 | |
02-24-2021, 01:38 AM | #14 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
I was going to buy those with the rest of the upgrades I’m currently doing because today For example, it’s almost a hundred here In Udon Thani and it’s February still and I’m sure Buri Ram (where the track is) the climate is the same. I postponed them to get other dress up and functional items because I don’t plan on being at the track until about the end of summer. But a 15 minute session here will be when it’s 100 and the “on track temp” is going to be scorching hot, damn near 140 probably. Rarely does anybody walk barefoot on asphalt in this country. But when I get them, I’ll make sure I run once prior to installation to get a baseline, and then I’ll have data. I’ll be the guinea pig if you’re willing to wait. It’ll be about 6 months before I get to the track. So I should be buying about that time.
