Old 03-14-2017, 10:12 AM   #15
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
They said the new formula for 2017 year vehicles has been submitted but not approved.
Old 03-14-2017, 10:26 AM   #16
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Wonder how long that's going to take to get it approved.
nancygrl is offline   Reply With Quote
Old 03-14-2017, 10:32 AM   #17
396ssrat
Drives: 66 Chevelle SS
Lucas..... Enough said
http://lucasoil.com/pdf/TDS_SAE-5W-40-MO.pdf
Old 03-14-2017, 10:41 AM   #18
jreagle56
jreagle56's Avatar
Drives: 2022 2SS A10 NPP MRC Red Hot
Seemingly Dexos certification = confusion ...... the oil forum is going through the same probelm.
FWIW It looks like Dexos 1 gen 2 is a revised list for 2017 with 777 less entries than before. Pennzoil Ultra isnt even on the list for Sept. 2017.
Dexos 2 seems to be the same list shown as last year; the same 155 entries; not seeing a new list for 2017 posted yet.
So would you roll with what is on the list or the bottle label?
Wonder what GM Dexos opinion would be?
http://www.gmdexos.com/owner/brands/
jreagle56 is offline   Reply With Quote
Old 03-14-2017, 10:57 AM   #19
1967RS327
1967RS327's Avatar
Drives: 1967 RS 327 Muncie, 2017 ZL1 6spd
What are the dealers using?
1967RS327 is offline   Reply With Quote
Old 03-14-2017, 11:07 AM   #20
WhyUMad1LE
Drives: 17 SS 1LE
What's the point of dexos2 in a gasoline engine? Emissions?
Old 03-14-2017, 11:42 AM   #21
jreagle56
jreagle56's Avatar
Great question.
Not sure what the ZL1 needs for track vs daily driving. The OP has that answer.
For the 2016 SS; the owners manual is specifying using Dexos 2 5w40 for tracking the car. Otherwise Dexos 1 Gen 1 is ok for daily driving.
FWIW The Dexos Gen 2 list seems to be oriented for the 2018 MY releases since it is effective Sept. 2017.
IMHO Requiring Dexos 2 for tracking seems like another hurdle in the warranty coverage program.
When asking the local dealer about Dexos 2; they seem to think i am referring to Dexos gen 2; 2 totally different topics adding more confusion for the consumer to wade through.
Old 03-14-2017, 11:47 AM   #22
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
There's a few things you need to understand before digging too deep into this. Especially for those to whom this is all new info.
First, we're discussing the recommended oil for track days - not daily driving, weekend cruises...stick to Dexos1 5w-30 for that.
Second, Dexos1 and Dexos2 are GM approval certifications, nothing more. They aren't "grades" of oil.
Third, the performance engineers recommend 0w-40, or 5w-40 for their viscosity while on the track and operating at high rpms and high temperatures. But here's the catch: Dexos1 doesn't certify an oil above 30 weight. Dexos1 is primarily for gas engines, and Dexos2 is primarily for diesel and Europe (emissions).
Normally, I'm a big fan of Mobil 1 0w-40 Euro blend...but I am planning to use the Valvoline 5w-40 specifically listed in the performance supplement, or the Motul 8100 X-Clean 5w-40 that meets Dexos 2 cert...unless something new comes out or earns a certification.
(I have no interest in running the Mobil 1 15w-50, and changing it every time I go to the track, though...)
EDIT: I find it very interesting that they recommend a Valvoline oil in print, because Valvoline fought very hard against Dexos1 certification when it first came out, even though they had oils that exceeded the requirements. That tells me the engineers did some homework with this one...
Old 03-14-2017, 11:51 AM   #23
James4086
James4086's Avatar
Drives: Black 2017 ZL1
Originally Posted by Mark114 View Post
That's interesting that there is a Mobile1 synthetic 0w-40 that meets Dexos2 but it only seems to be available in Europe?
http://www.mobil.co.uk/UK-English-LC...esp-0w40.aspx#
I think there's a local lube center (Mobil1) that handles that stuff. I didn't look to see where you are from before I started this post, but if they can get it in Prairieville LA, I'm sure you could get it sent to you from amazon or something. Most oil places will just charge you for a base oil change (minus a couple of dollars for bringing your own oil) and still do the change for you.
Also, +1 to Mr. Wyndham. It says on the description of dexos1 and dexos2 that "2" is for diesel engines and places with more strict emissions requirements. Also, the performance supplement only recommends the dexos2 stuff y'all have been talking about for track cars only. Day-to-day is supposed to stick with the 5w-30. I guess if you live in warmer climates (like here in LA) you could probably get away with the Xw-40 year-round because I've been running the DOT-4 brake fluid in my '13 ZL1 year-round too. However, unless I find a time when I'll have my car on the racetrack for more than a weekend at a time, I'm going to stick to the 5w30.
CAUTION: side effects of driving a Camaro include grinimus permintallis otherwise known as "Permagrin" and random, uncontrollable outbursts of "I love this car!!"
James4086 is offline   Reply With Quote
Old 03-14-2017, 11:54 AM   #24
I always used Pennzoil Ultra Platinum which is now Euro Platinum.
Doesn't appear to be Dexos 2 though.
Old 03-14-2017, 01:03 PM   #25
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
There's a couple things you need to understand before digging too deep into this. Especially for those to whom this is all new info.
^^^This
Those who do 1000 mile oil changes or track day changes, I can say that the Edge product is not bad at all.
I like Motul but it degraded the paper media used in a Fram filter a couple years back so I choose to change to Motul only prior to track day. I change back to Castrol after the sessions along with the AC Delco filter. I'm sure some of you are rolling your eyes on the frequency of oil changes but my philosophy has less to do with oil breakdown than it does with inspection.
Changing the engine oil allows me a peek inside the engine that is very valuable. It's often the first communication of a problem. You can even send your cars 'blood' off to a lab for analysis. I do that every 10,000 miles for about $28
Doesn't hurt to check the media type in your filter if you're sticking to a dexos2 for DD. The dexos 1 is a blend and easier on non-synthetic filter types. My thoughts, not necessarily lab facts...
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 03-14-2017, 02:18 PM   #26
thompstl1
thompstl1's Avatar
Drives: 2017 A10 ZL1
This link appears to name the oils that are both dexos 1 and dexos 2 approved;
http://www.centerforqa.com/dexos-brands/
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
thompstl1 is offline   Reply With Quote
Old 03-14-2017, 07:17 PM   #27
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
5w30 Mobil 1 extended performance in sure will be good for daily driving/spirited driving. I'm pretty sure it's dexos 1
Evolvedx27 is offline   Reply With Quote
Old 03-15-2017, 03:30 PM   #28
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
I see 0w-40 on EBay
greaser2 is offline   Reply With Quote
