Old 10-27-2019, 04:47 PM   #15
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Smile Possible way to extend battery life.
For your consideration-
I fully admit that I was a skeptic about super-capacitor boosters for vehicle batteries.
I presumed that the YouTube videos were probably just hype or wishful thinking.
However, based upon positive experiences with one on our truck, when I bought the Camaro and saw where the battery was located (and how much it costs) I added one.
It is 83.3 farads and is connected from the positive jump start terminal under the hood to the engine block.
If nothing else it stiffens the battery supply path in the engine bay after its long cable and chassis run from the trunk.
Just like on our truck it now cranks a bit faster and seems to recover quicker.
I also added one to our Cruze a while back and even when it sits at an airport parking lot for a couple of weeks (as it has far too often this year) it will crank over like no time has passed.
Your mileage may vary.... FWIW
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 10-31-2019, 11:46 AM   #16
zag
Drives: 2018 camaro 2 ss
could someone tell me how you remove that large black piece of plastic by the rear latch in the trunk after you remove the four plastic nuts? You need to remove it to remove the trunk liner from the trunk. Thanks
zag is offline   Reply With Quote
Old 10-31-2019, 12:11 PM   #17
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Originally Posted by zag View Post
could someone tell me how you remove that large black piece of plastic in the trunk after you remove the four plastic nuts? Thanks
It is sort of flexible like carpet with starch or something in it, so you just kind of gently bend it around as needed.
I have not had to replace the battery on my '16 SS yet, but I did remove the carpet-like covering in order to put a pigtail on the battery for a trickle charger I attach to it when the car is stored over the winter months.
Emoto is offline   Reply With Quote
Old 10-31-2019, 02:10 PM   #18
tecboy
tecboy's Avatar
there are a couple of clips on the top ...next to trunk latch...pull up as you are trying to remove and the clips will release...
found this video on replacing the battery..
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
