10-13-2020, 04:00 AM | #1 |
Drives: 2020 1SS 1LE M6 Riverside Bl Metall Join Date: Oct 2020
HPDE Day and OnStar 30 Day Free Trial?
Free Trial of OnStar for 30 days!
New 2020 1SS 1LE coming up to 1500 miles on the odometer, done the oil changes, Track alignment, and reviewed the settings for the Ride Control Systems. So I am ready for my first Track Day. But what about OnStar? Should I pull the fuse or unplug it? If so- Will that effect my other functions such as the PDR or anything else while at the Track? Has anyone else had an issue with any intervention or negative repercussions from OnStar at the Track? KEN |
10-13-2020, 04:49 AM | #2 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Your good, no need to do anything.
10-13-2020, 07:59 AM | #3 |
Drives: 2014 Chevy Volt, 2018 SS 1LE Join Date: Nov 2016
Most of us would advise upgraded brake fluid (Castrol SRF, Motul, Brembo HTC)
Sent from my SM-N950U using Tapatalk |
10-13-2020, 08:46 AM | #4 |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
If you are using the Cosworth tools you may need the GPS link. Just a guess. Unless your insurance company is using the data, just go and enjoy the car, GM could care less.
10-13-2020, 08:53 AM | #5 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I wouldn't pull any fuses or disable onstar or anything like that for a track day. It's plenty fine to keep active on track.
I'd second that swapping to some good DOT4 is a must before going to the track if you haven't done that already.
2017 SS 1LE.
10-13-2020, 10:33 AM | #6 |
onstar wont bug you on track unless you crash lol so dont crash!
10-13-2020, 01:26 PM | #7 |
Thanks for the replies re: OnStar question.
While I have your attention what are the 1LE's favorite fluids to drink for Semi-Competition (street/track car)? I know Castrol SFR brake fluid is #1 Engine Oil? (currently using Amsoil 0W-40 Signature Series Synthetic) Differential Oil? Tranny Oil? |
10-13-2020, 01:33 PM | #8 |
i track my 1ss i have stainless steel lines motul 660 and for oil i use torco 5w40 sr1 and oem diff and tranny oil
10-13-2020, 02:36 PM | #9 | |
My preferred diff oil is just GM's fluid, GM PN 88862624 or ACD 10-4034. MT oil I used Redline D4 ATF. OE fluid doesn't seem to work as well when temps get low.
2017 SS 1LE.
