04-18-2020, 12:11 PM | #1 |
Drives: 18'-1LE Join Date: Jul 2017
Charging the battery?
Do you guys think the battery trunk cover could have been somewhat larger?
WTF. |
04-18-2020, 12:29 PM | #2 |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
Question that can also interets me
04-18-2020, 12:52 PM | #3 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Much easier to charge by using the positive and negative lugs near the fuse box under the hood.
04-18-2020, 02:40 PM | #4 |
Retired from Car mfrs....
Go get a battery pigtail from battery tender… 5 bucks. Takeoff the side cover and the larger right hand cover once, and wire the battery… Have The pigtail coming out of the small cover… Never have to mess with this stuff again…
04-18-2020, 05:46 PM | #5 |
Drives: Grandad's C2 L89 Join Date: May 2017
^This^
2018 ZL1 1LE sw/PDR
04-18-2020, 06:42 PM | #6 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Not sure what they were intending on the battery access cover in the trunk. Its too small to accomplish much of anything. I run my tender connections thru the trunk area. Just pop the trunk, and plug it in. To install the pigtail connections I removed the passenger side trunk cover to access the battery... to properly bolt the connections up initially.
I my opinion its a lot easier than popping the hood to access the terminals there.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
04-18-2020, 06:57 PM | #7 | |
I don't see much difference between popping the hood or popping the trunk, and I didn't need to install pigtails. |
04-18-2020, 07:01 PM | #8 |
I think it's only meant to provide an easy way to disconnect the negative terminal. The liner needs to come out for anything else.
04-18-2020, 09:20 PM | #9 |
Drives: Chevy Camaro ZL1 Join Date: Apr 2020
My guesses for why GM located the battery in the trunk:
1. Better weight distribution. 2. Crowded engine compartment. 3. Less hostile environment for battery. I use the Camaro battery tender regularly and use the leads under the hood. Chris |
04-18-2020, 11:54 PM | #10 |
Drives: 14 Silvy 1500 Z71; 20 Camaro ZLE M6 Join Date: Jun 2017
04-24-2020, 10:07 AM | #11 |
Just two questions about disconnecting battery.
i would like to disconnect thé battery un thé trunk when the car is garage kept too longer. 1 can I just disconnect thé negative or must I have to disconect negative plus thé positivé one ? 2 if i disconnect thé battery, are my settings all kept ? (For example : the seats positions memories..) |
04-24-2020, 11:26 AM | #12 | |
2 I believe most of the settings are retained, but some things might need to be reset like the window indexing. |
04-25-2020, 01:14 PM | #13 | |
Mine was toasted because when the car was shipped they didn’t disconnect thé battery but just thé fuses box..... |
05-17-2020, 03:20 AM | #14 |
Hi everybody
I’m back on this because for important question. I would like to buy a battery tender but ... if I’m right thé tension used in Canada is 110 v... De have 220 v in France ... so i would like to buy a «*intelligent*» tender but if i get it from canada could I plugg it in a french electrical outlet ? Thanks |
