01-02-2019, 07:04 AM | #29 | |
Drives: 2018 Camaro 1SS Join Date: Jun 2018
2018 1SS 6MT: SOLD
01-02-2019, 07:06 AM | #30 |
Running catch can here. I can take this off in 5 mins if i need to go dealer. Lol
2018 1SS 6MT: SOLD
01-02-2019, 07:20 AM | #31 |
Drives: 2017 Camaro SS Join Date: Nov 2018
OK, that right there is pretty funny!
Kevin
Luceo Non Uro |
01-02-2019, 07:26 AM | #32 |
LOL OP don't worry about your warranty with a catch can. Also if you track (drag racing or road tracking) then the catch can is a good idea. But if not I wouldn't bother. While the idea that DI engines are a bit oil and carbon build up challenged and deposits can accumulate is true, has anyone here had that problem yet? Chevy has spent some engineering to prevent the problem.
01-02-2019, 07:38 AM | #33 |
Drives: Camaro Join Date: Sep 2018
01-02-2019, 07:39 AM | #34 |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
I absolutely do. He is a good friend of mine since we have worked together for many, many years.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
01-02-2019, 07:43 AM | #35 | |
Retired from GM
As long as there is not a tune involved there's nothing that will tell GM about the modification. But if for some reason the dealer says they'll charge you for work because you have a mod, GM will support the dealer on that. Clearly this is more likely with mods requiring a tune or otherwise detectable by reading the ECM.
01-02-2019, 08:10 AM | #36 |
Drives: '19 2SS M6. Join Date: Aug 2018
Unless your car shits the bed on the road and you have to have it towed to the dealer....just saying.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
01-02-2019, 08:52 AM | #37 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
01-02-2019, 10:01 AM | #38 | ||
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150 Join Date: Nov 2017
Very first thing I did on my car was order a JLT Catch Can. Installation takes <10min.
This x100 Quote:
If you forget to drain your catch can and/or it freezes up you could potentially have issues with a higher crankcase pressure. So if you do get one you have to periodically drain it.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold |
01-02-2019, 10:02 AM | #39 |
2018 1SS 6MT: SOLD
01-02-2019, 10:08 AM | #40 | |
2018 1SS 6MT: SOLD
01-02-2019, 12:06 PM | #41 |
Drives: 2018 ZL1 Join Date: Dec 2012
01-02-2019, 12:30 PM | #42 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
The Mishimoto can is small so I was checking it every two weeks in order to get a sense of its needs. Nothing dramatic until the temps dropped into the teen and then I found it completely full. Obviously, I was very concerned but the oil looked ok so I emptied the can and checked it four days later. That is the picture I posted (about 1/3 full). At that point I decided to remove the can and change the oil. The oil reeked like gasoline so bad the garage smelt like I spilt gas on the floor. I don't think the water in the can would freeze due to other things mixed in. Not sure though because my garage stays in the 40s regardless of outside temp and that is were I checked it. This is why I won't run my car with one and can understand GM not approving their use. It requires owner involvement for things not to go bad and they havn't tested them to validate.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
