06-16-2016, 11:28 AM | #1 | |
Check me out on YouTube!
Drives: 2016 Camaro SS Join Date: Feb 2015
*video* 12.12 @ 114 First time out - SS/A8 - 100% stock
No record breaking times, but considering the DA, I am very happy with the results. No doubt in our spring/fall air when it gets to negative DA it would go 11s.
Anyways, video & slips at the bottom if you just want to watch that. More thorough evaluation of the night before that if you want to read. *slips go from left (first) to right (last). My last/best pass is in the video* Headed over to our local track last Wednesday, Gateway Motorsports Park in St Louis (technically Madison, IL). The DA was around 2100 to start, far from ideal. Pass #1 - All TCS/Stabilitrak off. Stalled it up to about 1000, left pretty well. Pass #2 - All TCS/Stabilitrak off. Stalled it up to about 2000, spun a bit, bad pass. Pass #3 - All TCS/Stabilitrak off. Tried stalling it 1500, still didn't leave clean. Pass #4 - All TCS/Stabilitrak off. This time no stalling. Foot on brake, mashed it on green. Didn't work great. Pass #5 - TCS off/ Stabilitrak in Competitive. Stabbed throttle, left pretty well. Pass #6 - Same as above, time dropped a bit. (best 60') Pass #7 - Same as above, time dropped again. DA was down to 1300. This pass was just 7 minutes after #6, so hotlapping doesn't matter. *all passes were left in D If I get another night where it will be somewhat cool while it is still stock, I will go again. I figured out how to do Launch Control, so I want to see how well that works at the track. I've seen mixed reviews here. Seemed to work alright on the street.
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned 11.91 @ 117 - CAI intake only 11.99 @ 117 - STOCK 1/4 mile 410 RWHP / 424 RWTQ - STOCK Dyno --- YouTube Channel: BadBowtieProductions |
06-16-2016, 11:34 AM | #2 |
Bump in the night
Drives: '84 Monte Carlo SS, '15 Optima Join Date: Oct 2015
Good time, and looked like a ton of fun. You should submit those to the fast list.
EDIT: saw it's on there, found this post in new section.
06-16-2016, 12:45 PM | #3 |
Yup, seems pretty easy to go fast with these things stock. Would love to have ran in some ice cold air. Maybe I'll put it back to stock this fall and see what happens, if I've modded it by then that is.
06-16-2016, 12:48 PM | #4 | |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
Btw, that Stang that you're going up against, dude is a badass driver. 1.8 60 ft for a manual?? Skills! both of you. |
06-16-2016, 06:40 PM | #5 |
Drives: 2000 pontiac formula Join Date: Dec 2015
That's crazy fast for stock. Hope mine's as quick. I'm getting the A8 as well.
06-16-2016, 06:45 PM | #6 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
Keep the videos coming!
06-16-2016, 06:58 PM | #7 |
Drives: 2SS Camaro LS3 Join Date: Oct 2008
Need to work on your reaction time.
Leave on last yellow, work on timing from there. This is good .xxx this is not xx.xxx. It takes practice, I was running twice a week for a month then was able to consistently pull a .oo4 light. Of course I pushed that and started red lighting. Good luck.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block 67 Chevelle SS Big Block 05 Cobalt SS Supercharged 07 Cobalt SS Supercharged 10 Camaro 2SS LS3 Soon: 18 Camaro 2SS 1LE |
06-17-2016, 11:33 AM | #8 | |
I will for sure. Plenty more 6th gen stuff to come obviously!
06-17-2016, 11:38 AM | #9 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Nice passes Bowtie
06-17-2016, 11:55 AM | #10 |
Drives: Want a gen 6 Join Date: Jan 2013
What do you know about the Blue Mustang at the end? Stock? m6/pp?
06-17-2016, 11:56 AM | #11 |
Toyota Tech
Drives: 2SS A8 Join Date: Jul 2014
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114 Sold 2013 Chevy Crzue LTX |
06-17-2016, 11:57 AM | #12 | |
Toyota Tech
06-17-2016, 12:09 PM | #13 |
Drives: Car Join Date: Jun 2010
Rocket was referring to R/T which does indeed count time from green to you tripping the beam. Not 60'
BadBowtie, which drive mode where you in for these and was mag-ride (if equipped) set to match the drive mode or did you place it in a specific setting? |
06-17-2016, 12:28 PM | #14 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
