02-01-2021, 11:39 AM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
THROTTLE BODY ADVISE NEEDED!
I have a set of 2" catless headers going into a stock suitcase. A 14% lower pulley spinning a stock blower. A RotoFab Big Gulp. JRE will remote tune it.
My last problem is I can't decide on the TB. I have a NW 103, but that has to wait until next winter for the Maggie 2650. I'm leaning towards a LT5 TB with an adapter. But still, JRE, Soler, Pray, Katech, or who? What do you guys think. |
02-01-2021, 11:45 AM | #2 | |
Drives: '18 ZL1 1LE Join Date: May 2020
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
02-01-2021, 11:47 AM | #3 |
Drives: 2017 ZL1 A10 Join Date: Aug 2009
Katech
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
02-01-2021, 12:06 PM | #4 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Why don't you just use the 103 you have?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
02-01-2021, 12:09 PM | #5 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I'm having the same issue on a deciding which way to go. I currently have a soler TB that is 87 that is ported to 91 from them .I still have it brand new in box never used.
I'm going to have Jannetty to do a tune and not sure if I just get JRE LT5 or get Soler TB that is 95mm ported to 100mm. Not sure if it would be to much air what do you guys think? https://www.solerengineering.com/gen...ors/se9871-100 |
02-01-2021, 12:34 PM | #6 |
Drives: 6th gen Join Date: May 2020
If you open the snout with porting on the supercharger I’d run a bigger Tb otherwise run the 87
02-01-2021, 12:44 PM | #7 |
In Jannetty JRE package he runs the 95mm TB and he doesn't do any porting of the blower. Does the 87 to 95 or 100 have no impact on HP?
02-01-2021, 12:49 PM | #8 |
Everything that we’ve seen shows no gain of the 95tb if it eventually necks back to 87mm when compared to a well ported 87mm.
02-01-2021, 12:54 PM | #9 |
02-01-2021, 01:23 PM | #10 | |
02-01-2021, 02:38 PM | #11 | |
Dyno Show Queen LOL
watch this video at the 21:00 mark to see if the TB is important for PD blowers.. I used a 112mm you went with 2" headers why not stay with the plan to make everything as efficient as possible and work the blower less.. Big TB, ported heads, ported blower, 5 inch intake.. 2 inch headers.. you will make more power and if that's not your goal you will make your power level with a few less psi and rpms which is always good.
02-01-2021, 03:34 PM | #12 | ||
I always believed to big of a TB is not good because there is so only so much air that you can use and to big will choke the car. Sorry if I don't make sense |
02-01-2021, 03:58 PM | #13 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
02-01-2021, 04:21 PM | #14 | ||
