Old 11-24-2018, 06:39 AM   #1
vararam industries
vararam industries's Avatar
Drives: 2014 C7
Vararam Sneak Peak at new Air Intake
vararam industries is offline   Reply With Quote
Old 11-24-2018, 10:45 AM   #2
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
Teaser!
What are the benefits vs. the competition already out there?
BrianL is offline   Reply With Quote
Old 11-24-2018, 11:59 AM   #3
vararam industries
Drives: 2014 C7
Primary difference is the system delivers the flow required to support a true gain in power vs tricking the ECM to alter the tune wile gaining little to zero increase in actual airflow.
We gain over 1/2-3/4 of a pound of manifold pressure wile others tapper off down to 13.8-13.9 PSI @ 4,900RPM -6,000 RPM ! on a stock LT-1 ,that's well over 20 Rear wheel HP !
The ZL-1's are simply in another world !
Comparisons to others on those have seen over 1.5lbs of pressure added "over and above" some of the competition. We have tested on stock and modified ZL-1's and the VR is a "MUST HAVE" for any ZL-1 ,especially if it's been modified.
Construction materials - the materials have far better thermal-dynamic properties than Metal intakes with coatings and even the carbon Fiber intakes .
Showing real world temps that are lower by 20-30 deg F inside the manifolds plenum or inside the supercharger !
Quality - Using both Injection and Rotational molding yields a precise fit and internal aerodynamic package that rivals OEM .
There are a host of design features that will be shown in the coming week .
Stay tuned to our facebook page and the forums for latest updates.
VR tech
Old 11-24-2018, 04:01 PM   #4
Deputy Dog
Drives: 2017 Super Sport Cam.
Originally Posted by vararam industries View Post
Lemee see if I can explain in english...looks like a smaller air box...yet it will use the same air inlet hole the stock box uses. As a physics specialist specializing in H20...that means air, I'd say the smaller box would cause a more forceful and denser flow of air giving almost a suction effect into the intake...thus increasing HP and performance.....right?
Deputy Dog is offline   Reply With Quote
Old 11-24-2018, 04:02 PM   #5
Whocares05050
Drives: 2018 Camaro SS 1LE
I dont want the sound tube. If this thing cost more than 300 for just the airbox doubt many will buy.
Whocares05050 is offline   Reply With Quote
Old 11-24-2018, 04:25 PM   #6
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Interested in what you guys come out with for ZL1's.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 11-25-2018, 12:41 AM   #7
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
Afraid I already know the answer but have to ask since it seems to be a closed box as opposed to the WeaponX and Rotofab...Will this be CARB approved???
SienarSystems is offline   Reply With Quote
Old 11-25-2018, 01:10 AM   #8
Opus13
Opus13
Opus13's Avatar
Drives: 2017 Camaro 1SS, Black
+1 on sound tube delete and hopefully CARB legal.
"My entire life in one sentence:
It didn't go as hoped, but that's okay"
Opus ie. Berkeley Breathed.
Opus13 is offline   Reply With Quote
Old 11-25-2018, 11:38 PM   #9
KMPrenger
KMPrenger's Avatar
Had to chime in...
I had a Vararam on my 5th gen and loved it. It came out late also, but was worth it. I switched from an AirRaid to the Vararam and the difference in sound and power was noticeable.
I'm a fan.
Old 11-26-2018, 02:17 PM   #10
vararam industries
Drives: 2014 C7
They are going to Love the Power , The real world performance and the quality.
Not to mention super fast install time ! 5-8 Min max!
VR tech
Old 11-26-2018, 03:42 PM   #11
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
You should change your banner to LT1 and LT4
WCKD 1LE is offline   Reply With Quote
Old 11-26-2018, 03:59 PM   #12
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Where are the pictures of the installed kit
Old 11-26-2018, 04:08 PM   #13
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Following!
Sledgehammer70 is offline   Reply With Quote
Old 11-29-2018, 10:13 PM   #14
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
all so following
blk 2013 is offline   Reply With Quote
