Old 06-19-2016, 11:32 PM   #1
srossi5
Drives: White 2016 camaro ss M6 npp
Secondary cat delete with NPP
Over the weekend I had the secondary cats removed on my 2ss. The car sounds awesome IMO and just wanted to share since im new to the 6th gen community.
srossi5 is offline   Reply With Quote
Old 06-20-2016, 08:42 AM   #2
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
Originally Posted by CreativeDawn View Post
You won't get a CEL with a secondary Cat Delete right?
Correct, 3 months on mine still no code.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 06-20-2016, 09:17 AM   #3
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Sound clips?
Old 06-20-2016, 10:24 AM   #4
srossi5
No cel so far as long as the welds are good it should be fine sound clip is in track mode.
https://m.youtube.com/watch?feature=...&v=st8-GdU2VsE
Drive by
https://m.youtube.com/watch?feature=...&v=_zQR0oF_MMo
Old 06-20-2016, 10:58 AM   #5
srossi5
Thanks IMO its the best bang for your buck mod it only ran me 200 and it was done in less than an hour
Old 06-22-2016, 01:08 PM   #6
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
Did you buy the kit or just have some fab'd up at a muffler shop?
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 06-22-2016, 01:13 PM   #7
elpatofeo
LawBraker
elpatofeo's Avatar
Drives: 10 SIM 2LT/RS & 2016 1SS Hyper Blue
Will emissions be an issue when it's time to smog? Not much of a mechanic but I would think the CATS are there for a reason.
elpatofeo is offline   Reply With Quote
Old 06-22-2016, 02:24 PM   #8
srossi5
Emission may be an issue i am not sure but the primary cats are still on so i should be ok and i did not buy a kit i had the cats cut out and welded in a pipe like is seen above
Old 06-22-2016, 03:57 PM   #9
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
Drive by
Sounds really good! Did you go with 2.75" pipe or 2.5? Did they weld all the way around and did they have to drop the exhaust to do so?
somewhatdamaged is offline   Reply With Quote
Old 06-22-2016, 04:07 PM   #10
srossi5
They only had 2.5 and they had a flexible tool to make sure the pipe was welded all the way around because it is in a tuff spot. Also they left the exhaust on the car and just cut the secondary cats out and welded the straight pipes in place while it was on the lift
Old 06-22-2016, 04:41 PM   #11
somewhatdamaged
Drives: 16' 2SS M6
Thanks for the feedback! Sounds like a great way to get a bit more sound/growl from the NPP without breaking the bank. Do you know how big each section of pipe is that replaced the secondary cat? Do you think two, one foot sections would be enough?
Old 06-22-2016, 05:50 PM   #12
srossi5
I would say about 10 inches but the miffler shop should be able to measure it out for yoy so its a good fit
Video in stealth mode
https://m.youtube.com/watch?v=3ecz4T...ature=youtu.be
Old 06-25-2016, 11:40 PM   #13
VR2011-HBM2016
VR2011-HBM2016's Avatar
Drives: 2016 Hyper Blue Metallic 2SS
I agree with you there. I just want some more growl from sport/track and it be quiet when I need it to be.
New Camaro Build
http://www.camaro6.com/forums/showth...35#post9170635
2011 VR 2LT RS/White Rallies/Lots of Memories
Old Camaro Build (Red Menace)[/B]
http://www.camaro5.com/forums/showthread.php?t=224921[/CENTER]
VR2011-HBM2016 is offline   Reply With Quote
Old 06-26-2016, 02:12 AM   #14
Razzaa
Razzaa's Avatar
Secondary is the rears? I'm new lol
Razzaa is offline   Reply With Quote
