03-20-2019, 05:22 PM | #1 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
ZL1 (not 1LE) Track Alignment
(I searched first)
I ran slightly more that the recommended maximum front negative camber last season -2.3/-2.4. The Track Prep Manual says -2.0 +/- .15. Front tire wear was fairly flat, but is there a benefit to going back to the recommended range or should I just get as much as I can get? Rear tire wear was noticeably more on the inside. Alignment is scheduled for Friday afternoon, so a quick response is appreciated.
03-20-2019, 08:10 PM | #2 |
Drives: ISO ss 1le Join Date: May 2018
As you get faster, you’ll start to notice more outside wear on these heavy cars. I think -2.3 is a good starting point on track, leave it be, as i don’t think you’ll notice a favorable difference.
03-21-2019, 07:34 AM | #3 |
aka BeastZL1
Thanks.
Sent from my iPhone using Tapatalk Pro
03-21-2019, 09:38 AM | #4 |
Drives: 2017 SS 1LE Join Date: Mar 2016
Yea it really depends on how much you are drive on the street vs. on the track and how hard you are pushing on track. I've been running -2.5 front and -1.5 rear on my car and the tire wear is pretty good though I am seeing a bit more outside shoulder wear up front so it my be time for a bit more front camber.
IG: @NC_M1SS1LE
03-21-2019, 03:51 PM | #5 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Id max the F camber and just be done with it. I got mine to 2.6F with 1.6R. If you do it id see if the could normalize L vs R rear camber to 1.6 on both sides. PS The toe looks good and within nice comfy spec range.
03-21-2019, 04:06 PM | #6 |
Drives: ZL1 A10 Join Date: Dec 2017
That is the GM recommended front camber because that is the most that is easily attainable with the stock equipment. The inside wear is likely from driving the car on the street.
Personally I run -3.0
My rides:
2017 Camaro ZL1 A10 2015 Jeep Grand Cherokee Diesel 2012 Audi S4 1992 Porsche America Roadster 1990 BMW 325Ic |
03-22-2019, 08:49 PM | #7 |
aka BeastZL1
Dealership did it and came back with -2.6/-1.9. I think it is bullshit and they just tried to match the ZL1 1LE minimums. Car drives straight, so we'll see.
03-22-2019, 09:36 PM | #8 |
leave it...should be good
03-22-2019, 11:30 PM | #9 |
03-24-2019, 04:49 PM | #10 |
Drives: 19 SS 1LE Join Date: Nov 2018
03-24-2019, 06:40 PM | #11 | |
No unusual wear on inside shoulders. Personally I'd prefer to have a car set up for best handling regardless. I'd simply watch the F tire wear and make a longer term decision based on it. The rear is not far off GM specs anyway. The chances are you'll go thru a set fast enough anyway if you drive it hard enough - track or not... |
03-25-2019, 09:59 AM | #12 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I'm running -3* front and -1.5*rear on a autocross only car, but I will be running a few trackdays this season so it looks like I should have decent wear with what others are running.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
Tags |
camber, camber setting, track alignment, zl1 |
