Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
JUICEDMOTORSPORTS
Old 06-22-2019, 01:45 PM   #1
Booher
Booher's Avatar
Drives: 2017 Krypton green 2ss
Wideband model difference
What are the differences between the aem wideband 30-3000 and 30-0334. I've been trying find the difference but have had no luck. Just trying to figure out which one to buy. Also, do you have to have a mount for this or can I just throw it in my lap or cup holder? I only want it for a tune then it's coming out.
Old 06-22-2019, 02:00 PM   #2
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
I think you mean the 30-0300 (typo). Either will work. The 0334 interfaces through the OBD port on your car to bring in the sensor signal. The 0300 model requires you to wire in your signal input through the 0-5V analog input provided.
Both use the same Bosch 4.9LSU sensor and AEM wideband controller technology.
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger | E-60 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust with Cat deletes | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 06-22-2019, 03:45 PM   #3
Booher
Booher's Avatar
Yes, oops, ok thankyou sir, now I know which one to order.
Old 06-22-2019, 08:05 PM   #4
Trochoidal
Drives: Camaro SS
You can rest it in your cup holder or seat. The back will be exposed and shouldn’t cause any issues for temporary use.
Old 06-22-2019, 10:32 PM   #5
Booher
Booher's Avatar
Bitchin', that's good to hear.
Old 06-23-2019, 05:25 PM   #6
chaoscentral
chaoscentral's Avatar
Drives: 2016 Camaro 1SS
That's how I got mine setup while tuning. I wired the positive and negative wire to a 12v adapter and plug it into the power port. The O2 sensor wire I got running through the sound tube hole.
Red Hot 2016 Camaro 1SS 6M w/ NPP Exhaust, Speed Engineering 1 7/8" long tube headers and catless xpipe, lethal garage flex fuel kit, self tuned
chaoscentral is offline   Reply With Quote
Old 06-23-2019, 06:08 PM   #7
Booher
Booher's Avatar
That's a great idea, and only $7 on Amazon. Thanks for the pro tip, lol!
Old 06-23-2019, 11:46 PM   #8
Trochoidal
Drives: Camaro SS
Chaos, that’s the same thing I bought too. That way you can just use it when you need and possibly help a buddy one day and save him a few bucks! With the ease of the pass-through of the 30-0334 getting data into HPT is simple.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
