Old 06-13-2019, 11:28 AM   #1
smkymntn
Smoky
Drives: 2018 1SS
Fuel IT Bluetooth E85 reader
Hey guys. I have the lethal garage FF kit installed and activated with HPtuners. I wanted to use Fuel ITs bluetooth harness to access e85 contect percentages. Has anyone tried and had success?
smkymntn is offline   Reply With Quote
Old 06-24-2019, 03:57 PM   #2
parbreak
Drives: 2017 50th Camaro SS
I would be interested in knowing this too, and if it is compatible with the DSX flex fuel sensor.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 06-24-2019, 05:32 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
Good post! My FF is DSX and this would be a better option if HPT isn’t handy.
According to Lethal’s site he’s using genuine GM sensor.
https://www.lethalgarage.com/product...-gen-camaro-ss
Also looks like DSX is also using genuine GM sensor.
https://dsxtuning.com/collections/fl...nt=30058449867
Both of these meet Fuel IT’s requirements.
https://www.fuel-it.com/bluetooth-flex-fuel-analyzer/
Damn! Now that’s another “tool/gauge” on the wish list.
Another thought is I’d like to get the Aeroforce multi gage. It’s some extra money but could show E content and other PID’s.
Decisions, decisions.
Old 06-25-2019, 08:33 AM   #4
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
I have the AF gauge, it's nice and gives you all kinds of stuff to monitor.
51FIFFT is offline   Reply With Quote
Old 06-25-2019, 12:34 PM   #5
smkymntn
Smoky
Drives: 2018 1SS
I recevied the Fuel it and just need to install. Just filled up tank with e85. Ill install Fuel it tonight and update
Old 06-25-2019, 12:57 PM   #6
Umbriel
Drives: 2016 Camaro SS
Hey I sent you a PM asking this but does your AF gauge read any higher than 73? Mine won't go any higher even with known 84$ in the tank. Someone else was having the same issue.
Umbriel is offline   Reply With Quote
Old 06-25-2019, 05:56 PM   #7
Trochoidal
Positive reinforcement like this is going to cause a brown box to show up sooner than later. Thank you for the input. I’m glad I like Ramen!
Old 06-25-2019, 07:23 PM   #8
smkymntn
Smoky
Drives: 2018 1SS
Success
Installed fuel it and it works as advertised!!
Old 01-11-2021, 02:08 AM   #9
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
Can you take a picture of your setup with installed? I’m curious to see how it looks like after installation and I am wondering do I have to remove the e85 pin again for this setup.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 01-11-2021, 11:22 AM   #10
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Idk how I never saw this post, lol. I've had this for well over a year now, it works fantastic, and I love it. It works perfectly fine with he dsx kit, and I'm sure It would work with any branded kit out there. It's just a plug and play, and no you don't have to remove the pin for your e85.
Old 01-15-2021, 04:24 PM   #11
Blackmonba6Gen
BLUPRINT_1LE
THXi i'll go ahead and order one.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-19-2021, 12:29 PM   #12
Blackmonba6Gen
BLUPRINT_1LE
Which one did you’ll purchase? The Bluetooth only version? I ordered this particular one and I get a P0131 code where it get a low voltage. Before I didn't get any CEL.
Update : So i got a response from Fuel It: Apparently the 6th Gen camaro NEED the Bluetooth with the raw signal output. I am passing this info along to prevent others from ordering the wrong part due to lack of info. In hindsight it did work just fine and I know what ethanol content I have but i got a CEL.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
