Old 06-03-2019, 03:49 AM   #1
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Reset Remaining Oil Life?
I'm looking for the procedure to reset the oil remaining life.
I know about hitting the gas pedal three times.
How do you reset via the steering wheel - DIC?
Reading the manual, I can't seem to get it done.
2018 1LE
What is the simple procedure using the method below?
1>2>3>4
The Specialist is offline   Reply With Quote
Old 06-03-2019, 04:22 AM   #2
JeromeS13
Drives: 2017 1SS/1LE
Nothing to do with the gas pedal.
Go to the oil life screen in the DTC. Hold down the OK/select button until it resets.
Old 06-03-2019, 04:56 AM   #3
The Specialist
There is way to reset using the Gas Pedal. I haven't tried that.
I have found the " Oil Life " in the DIC. I'm not sure what to do next. I can't seem to figure out how to bring up the page and reset.
Do you have the procedure to walk me through it step by step? I need to find out what I'm doing wrong.
Old 06-03-2019, 05:29 AM   #4
JeromeS13
Straight from Page 26 of your owner's manual:
Resetting the Oil Life System
1. Display the REMAINING OIL
LIFE on the DIC. See Driver
Information Center (DIC) 0 130.
2. Press and hold SEL on the DIC
while the Oil Life display is
active. The oil life will change
to 100%.
The oil life system can also be reset
as follows:
2. Fully press and release the
accelerator pedal three times
within five seconds.
See Engine Oil Life System 0 259.
Old 06-03-2019, 05:30 AM   #5
JeromeS13
And numerous videos on YouTube:
Old 06-03-2019, 01:26 PM   #6
The Specialist
Thank you,, I'll follow this tonight when I get home. Apparently I've been in the wrong place on the DIC. I was scrolling through different areas. Found oil, but I could not open the page. Oil " Life " is what I need to be looking for.
Thanks again,
