06-01-2019, 10:10 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Gauge location
Hi guys. Just curious what everyones doing for adding gauges. Pillar mounts, vent mount, ect. Care to sharr any pics and advice? Thanks Ryan
06-01-2019, 01:00 PM | #2 |
Drives: 2013 Black SS M6 Join Date: Sep 2015
I just bought the dual gauge pillar package from Glowshift. They offer several color options and the gauges are dimmable from the interior light switch (if you choose to wire them that way). Glowshift offers plenty of gauge options. I'm installing a cam next month and my car doesn't have the 4 gauge cluster. So, I went with the oil pressure and oil temp gauges. Sorry, no pics yet. I'm still waiting on them to arrive. You'll probably get a lot of good advise on this subject.
06-01-2019, 03:35 PM | #3 | |
Drives: 2011 Camaro SS Join Date: Jul 2017
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
06-01-2019, 06:07 PM | #4 | |
I got the same deal! Oil pressure, oil temperature, and pillar shipped for $150! I'm thinking about installing the sensors in Glowshifts oil filter sandwich adapter plate. Seems like an easy install. |
06-01-2019, 09:06 PM | #5 | |
06-01-2019, 09:43 PM | #6 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Mine:
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
06-02-2019, 09:12 AM | #7 |
Thanks for sharing. Looks awesome
06-02-2019, 11:34 AM | #8 |
I liked the defrost vent replacement, too. Looks good and a little more out of the way. I only chose the pillar pods because I want the oil pressure to be easily noticed. I've also seen a dual gauge bezel that replaces the bezel around the speedometer and tachometer. The gauges are located down low and look good, too.
Thank, Jason |
06-05-2019, 10:32 AM | #9 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Mine
Vent and steering wheel gage pods
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
06-05-2019, 10:59 AM | #10 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Single gauge vent pod:
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
06-05-2019, 11:01 AM | #11 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Don, I think he was wanting to see pics of the gauges in a camaro... not the cockpit of a 747.
Here's mine....
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
06-25-2019, 01:18 PM | #12 |
Got my Glowshift gauges installed. I still need to install the 02 sensor in my exhaust. The A pillar pod is kinda crappy but it will do the job.
06-25-2019, 03:26 PM | #13 |
06-26-2019, 05:45 AM | #14 |
