Old 03-13-2019, 07:01 PM   #29
hotlap
hotlap's Avatar
You guys should post your times on the fast list. If you haven’t already.
Nice times
Ronald Reagan -
Old 03-13-2019, 11:56 PM   #30
NASTY_1LE
NASTY_1LE's Avatar
Drives: 2018 SS 1LE
Only 2 runs earlier but my best was a 12.971
Stock
I need practice
2018 SS 1LE
NASTY_1LE is offline   Reply With Quote
Old 03-22-2019, 10:45 AM   #31
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by yotaman96 View Post
...but I ran another 12.3 before installing the intake. Factory tires and slipping the clutch at the line.
Hey man, post the slip for the stock run in the fast list thread...we need more SS 1LE's on there. I added mine...
Old 03-31-2019, 03:19 PM   #32
straightjacket1le
Drives: 17 Hyper Blue 1SS 1LE
I just picked up a bone stock 17 SS 1LE. I hope to get it out to the track as soon as temps here in Michigan steady out a bit.
straightjacket1le is offline   Reply With Quote
Old 03-31-2019, 04:02 PM   #33
DFW1LE
DFW1LE's Avatar
My car was putting down big power, so I was expecting a low 11sec run, however, I had not been on a drag strip in over 50 years. Using MT ET Steet Rs @25 lbs and launching at 3500, I had a 2.01 60' and ended up with a 12.5 sec run. I spun through 3 gears and was not using NLS either. Anyhow, practice and experimenting to see what works is the way to go, but as old as I am, I decided to sell the car and bought an Audi RS5 instead. I also suspect if you are tuned by someone like Pray, that will help a lot as well.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 04-10-2019, 01:48 AM   #34
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Make sure to get a tire
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 04-10-2019, 05:10 AM   #35
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
um......WOW how much power are you making to lift up this beast?
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 04-10-2019, 05:47 AM   #36
ScatPack
ScatPack's Avatar
Drives: None at the moment
Best I did in my bone stock 1LE on stock tires was 12.7. That was all she had on the stock tires.
ScatPack is offline   Reply With Quote
Old 04-10-2019, 09:18 AM   #37
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
That looks like you broke my time also looks like you dropped the clutch!
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 04-10-2019, 09:33 AM   #38
JonD
JonD's Avatar
Drives: 2018 SS 1LE
479/476
If you can only imagine the timing system did not work... going back Friday if I can
Old 04-26-2019, 11:00 PM   #39
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Well my ET sucks from bogging but 123mph Trap speed in 5,000 DA is on the upper end
Old 05-02-2019, 03:13 PM   #40
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
Wow, 123mph is hauling! Sounds like you have just the right mods
z28pat is offline   Reply With Quote
Old 05-02-2019, 06:09 PM   #41
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Yup, I’m glad I went with the Pray Ported items & then my brother is the tuner who’s been tuning for 15 years so that’s a bonus for me in my state.
123mph at the stupid AZ DA was a win for me... can’t wait until it hits the lower 2,000 DA for a re-run
Old 05-02-2019, 07:10 PM   #42
NickeyMatt1LE
Drives: 2017 Camaro SS 1LE
Yep, gotta get a drag pack. I went 1.63 60' with a Hoosier 28"x10". If you do a slick on an n/a 6th gen, definitely go with a 26" tire. the 28" is too tall.
NickeyMatt1LE is offline   Reply With Quote
