Old 01-30-2019, 08:40 AM   #15
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Originally Posted by G2K View Post
Glad more people are going to the 1/4 and not just sticking to 1 discipline... these cars are good at whatever you throw at it...
Good to see some more come around... I currently am the record holder as per the forums list... but im the only 1LE on the list so its kinda crappy :P
Glad we will have more on there soon.
what tires are you running in the rear, only reason why i haven't gone to the track with my et street r's is i'm afraid i'll break the stock driveshaft and or axles.
I had purchased aftermarket ones to find out we have a different spline from the SS and can't use them. You aware if we have the stock driveshaft and axles from a ZL1? i mean if anything i can just slip the clutch and go for it. but some real times will be coming from a good launch. at that i'm even hesitant on warming these tires up (from a burnout) i just don't want to break stock parts to put stock parts back in. doesn't make sense to me.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 01-30-2019, 08:55 AM   #16
JonD
JonD's Avatar
Drives: 2018 SS 1LE
ayeeee MT-R's are the best tires IMO. My car transformed itself when i put these tires on.... dont want skinnies too lazy to be swapping tires every time i go to the track or mexico...
Yea I figured I’ll Just go for it as I won’t 1320 it a ton but when I do get the chance to go I want the best times I can muster here in AZ
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 01-30-2019, 10:48 AM   #17
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Im on the same, Mickey ET-R 305/45/17 28"
I do burn some clutch on launches, no issues at all. Check out my IG for videos of my launches. I actually almost pull a wheelie on stock fronts!!!
Regarding the axles; from the research i've done, I've found out that while the diff is the same as the ZL1 the axles are the same beefiness as the ZL1, but 1 is shorter in length.
Also the record bolt on car for an M6 is an SS and hasn't broken anything and he's doing 1.5x 60' I did a 1.5 once... my avg is 1.7 60'
I launch at around 4500rpm. I was scared but the care handled it.
Btw i follow you on YT, keep uploading videos I love your car! Cant wait till I go cam.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 01-31-2019, 06:35 AM   #18
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
This Weds? I'd be down.. I was going Friday with was aroun -300DA but there was a Jetcar event
sigh... they didnt do test and tune yesterday not sure why they took it off the schedule so rain permitting ill be going friday I really need to get my trans dialed in..
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 02-08-2019, 09:33 PM   #19
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Second pass here in AZ, the DA was about 1,800 to 2,000
11.683 @ 120.5 mph
ARH Full System
RotoFab CAI
e85 Tune by NicD
Old 02-09-2019, 07:48 AM   #20
18ss376
Drives: Camaro
Great job, out track doesn't open until mid March.
18ss376 is offline   Reply With Quote
Old 02-09-2019, 07:51 AM   #21
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Thanks, track was jam packed so barely got 3 passes in, the 3rd pass with a decent burnout had me hook so well that I bogged at 3200rpm and it was a wasted pass. Next time I’ll get that 1.6 - 60’ and get my 11.4 before I order the ported manifold & 95mm TB.
I’m going to shoot for 11.2’s with bolt on’s so it’s going to be tough
Old 03-10-2019, 01:32 PM   #22
LS6-M22
Rockcrusher
LS6-M22's Avatar
Drives: 2017 SS 1LE
I ran a 12.7 bone stock in 2000DA at Bradenton yesterday. I know theres a lot left on the table as my 60foot sucked and I didn't even mess with my tire psi
LS6-M22 is offline   Reply With Quote
Old 03-10-2019, 08:50 PM   #23
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
12.3 at 113 has been my best. Only mod is Roto-fab CAI, but I ran another 12.3 before installing the intake. Factory tires and slipping the clutch at the line.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 03-11-2019, 07:28 PM   #24
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Ran a 12.32 at almost 116 just recently. Bone stock, DA was around 800. Just added my slip to the fast list thread.
Old 03-12-2019, 12:08 PM   #25
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Great times guys... I could never do less than 13.0 when I was stock... :( you guys could problably get my car down to low 11's or high 10's :P
Old 03-12-2019, 08:38 PM   #26
yotaman96
yotaman96's Avatar
Our mph was really close at the 1/8th mile, then you just destroyed me.
2002 Trans Am
Old 03-12-2019, 10:03 PM   #27
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
It was HOT when you ran at Camaro Fest. Nice launch / 60 ft.!!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 03-12-2019, 10:24 PM   #28
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Still amazing how close our ET’s are...I think with a few more passes I can get at least a 12.2x out of it. But I think that is it for trap speed. (I only have made five passes.) But autocross season starts soon, so a return trip to the drag strip will have to wait.
