06-02-2017, 05:34 PM | #15 |
Drives: 1SS-1LE Join Date: May 2017
Do you also offer the cap for intake side of the sound tube? I would like to remove the thing but still have stock air box. I currently have the firewall plug in my shopping cart on your site.
06-04-2017, 01:31 AM | #16 |
on another thread someone used a 1" plastic patio chair cap. anything 1" will work with a clamp for the intake.
06-04-2017, 03:10 PM | #17 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
06-10-2017, 10:13 AM | #18 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
outside of the sound noise supposedly being pumped in.... I'm assuming that's the main "gain" from this mod.
my question is, is it a significant reduction in noise? looking to do this.....I guess..... but if it doesn't really do much as far as sound reduction, then I may just leave it till boredom kicks in.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-10-2017, 11:36 AM | #19 |
didnt notice anything. I removed mine so I could install a catch can.
03-26-2019, 10:01 AM | #20 | |
Drives: 2019 Chevrolet SS Join Date: Mar 2019
03-28-2019, 02:44 PM | #21 |
Its in the sale side of the forum this link works.
https://www.camaro6.com/forums/showt...91#post9753091 |
03-29-2019, 11:49 AM | #22 | |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
04-02-2019, 09:21 PM | #23 |
I removed the sound tube on mine literally about a week after I bought the car.
If you have a 3D printer or access to one, you can download the part files from Thingiverse here to do the job. https://www.thingiverse.com/thing:3267691 (updated version) https://www.thingiverse.com/thing:3127222 (original version) I have had these on my car for a long time now and they made a large improvement.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
04-09-2019, 08:12 AM | #24 | |
@texan.1le
Drives: '18 Camaro 1SS 1LE, PDR Join Date: Jun 2018
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily |
04-10-2019, 09:01 AM | #25 |
My only known point of reference is my V6 car, so I cannot say with 100% certainty that the intake tube end plugs will fit a V8 (I presume your SS is a V8).
But no one so far out of hundreds of downloads has complained to me about that, so........ ? The firewall plugs on the other hand should work for all gen6 cars because the holes in the firewall are all the same. The best thing to do would be to measure the tube on the intake end. If it is about 30mm (1.2") inside diameter and 35-45mm (1.4-1.8") in length any of the plugs I posted should work fine. My suggestion would be to go with the threaded ones (see below) because they are the easiest to install and are the most accommodating for length. But the three screw versions work great too and you can always have your buddy scale them length-wise when printing them. Which ever ones you choose, print them with a high percentage of infill so they are strong. Be sure to fill the edge troughs with silicone RTV to make good air seals. I put RTV on the threads too so they cannot back out on their own, and so far they haven't. If for some reason the dimensions of the intake tube end connection on your car are way different than the above, please take some measurements and a photo or two and I'll try to design something to fit.
04-10-2019, 09:43 AM | #26 | |
@texan.1le
04-10-2019, 10:25 AM | #27 |
You are most welcome and I will be very curious to find out. Thanks!
If worst comes to worst, I will be happy to design a plug for you that RTV's in from the outside with a flange to prevent it from possibly being sucked in. I could also design it to have small ribs to make a tight press fit. Because on the V8s the plug is on the top side that shouldn't be an issue, whereas on the V6s it is on the bottom and the tube is very thin so it needs something to clamp it into place (hence the two part inner/outer design). The closed cell foam and fender washer are available from almost any home improvement store. I used this foam specifically- https://www.lowes.com/pd/Frost-King-...lation/3427634 It is also very useful stuff when chasing rattles and air leaks in cars so I always keep a roll of it on hand. And it can be used for its original purpose (pipe wrap) if your car's A/C pipes sweat a lot or you just want to cover them up. But any closed-cell foam tape that is about 1/8" thick will work fine. Wrap it around the plug face against the firewall. You don't want to go too thick though because it will only make the plug more difficult to push in while twisting it into position. The fender washer is optional, however if you can find one it does help clamp the plug securely against the firewall and prevent it from warping (it is only printed plastic after all).
04-10-2019, 11:39 AM | #28 | |
@texan.1le
Thanks for the heads up on the foam tape. Looks like I'm headed to Lowe's today at lunch!
