06-18-2019, 02:07 PM | #57 | ||
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
EDIT: Another question is, will you be able to remote tune my car after I install the Maggie and the CAI and what do I need for that? |
06-18-2019, 02:11 PM | #58 |
Makcamaro, we probably have a dealer in the UK, let me find out who that is for you.
06-18-2019, 02:28 PM | #59 |
Makis
That’s fantastic. Please let me know. I might be able to convince a friend of mine who owns a 2018 SS, similar to mine, to supercharge his car as well
06-18-2019, 02:40 PM | #60 |
That would also be awesome. I'll PM you when I find out.
06-19-2019, 03:31 AM | #61 |
Makis
My question would be which one is better: the Magnuson TVS2300 Heartbeat, or the Whipple? I am doing my own research of course, but any input from people who have already installed any one of those systems would be very much appreciated. What are the advantages and disadvantages of one over the other?
Also regarding the tuning of the car after fitting the supercharger, is this included in the price? And can this be done remotely? I apologize for asking all these questions publicly, but I am completely novice on this platform and I think that other people can benefit from the feedback received as well. |
06-19-2019, 06:51 AM | #62 | |
You can get a generic tune with either supercharger included for free, but these won't be as good as a custom tune. Since you have an A8 trans, you'll very-very likely want that tuned as well, which basically means custom tune (and, when done right, an excellent transmisson). Remote tuning is possible just like on many other platforms, for example, with HP Tuners.
06-19-2019, 09:33 AM | #63 |
Where did you get the info that the Magnuson has lower IAT's? It has a little better efficiency which allows it to make similar power as the bigger Whipple but it still has to spin faster to make the power. The Whipple has a larger heat exchanger and IC system. I agree both are good units!!
2016 NFG 1SS A8
06-19-2019, 11:45 PM | #64 | |
Again, I never had a Whipple and a true apples to apples comparison is difficult to find. I don't think the difference would be large, but it appears to be consistent, nobody claimed lower IAT's with the Whipple, unlike the other way around. Happy to be corrected if you have experience with both systems. Heck, in the end I could hardly make up my mind, they both spec'd and tested so good.
06-20-2019, 09:02 AM | #65 |
That is because in the link you posted the OP was running 16psi. Lol are you running 16psi? Both the Whipple and Maggie need additional cooling mods for that boost level for summer days to keep timing from being pulled.
My Whipple @ 8-9psi (where the average user will be) doesn't even go up 15 degrees after a pull. 70 degree day my supercharger IAT's stay around 105 cruising. I ran 5th gear out on a 85 degree day and they never went over 132. That thread you linked is also cluttered with info from Centri guys that really don't understand the differences. PD blowers IAT sensors are located in the bottom of the charger down by the head. Centri's located in a much cooler spot. You have to tune the IAT spark retard table differently between the 2 to account for that. Mine doesn't pull timing until IAT reaches 154. So far from what I have seen it has never gotten close. 85 degree day, after a hot start, IAT's are 138...They come back down into the 120's not even a half mile down the road. I'm sure it probably makes a little more power when it's 50-70 degrees out but for the most part, PD blowers and high IAT's are highly over exaggerated and misunderstood for the most part. Anything running 16+ psi is gonna generate some significant heat in the summer. You are basically doubling the engines Horsepower compared to what it would make Naturally Aspirated at those boost levels.
2016 NFG 1SS A8
06-20-2019, 09:12 AM | #66 |
Makis
Good info.
06-22-2019, 08:13 PM | #67 |
Drives: Summit white 2SS Join Date: Feb 2017
Question for anyone running the 2300 heartbeat with just CAI, headers, tune on an M6 6gen. Do you get weird supercharger lag? Sometimes when shifting gears and then laying into it there is a solid 2-3 second delay before it gives me all the boost at once.
2016 summit white SS with 2300 Maggie Heartbeat, Rotofab CAI, kooks headers. Michelin PS4S tires.
06-22-2019, 09:37 PM | #68 | |
06-24-2019, 12:40 AM | #69 |
Sounds like a Tune issue.
2016 NFG 1SS A8
Tags |
supercharger, supercharging |
