05-30-2021, 03:23 AM | #1 |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
When to address traction?
Is there a good rule of thumb concerning horsepower/torque and tire width? I have the stock Goodyear runflats on my car now and they are indeed a sticky tire, but I will soon be around 500 rwhp/tq, car is an M6. Would a better tire in the stock width be sufficient? Edit: Street driven car, not drag racing but want to be able to use the power confidently.
05-30-2021, 05:24 AM | #2 | |
Drives: 2018 1SS 1LE Join Date: Dec 2012
Run it as a street tire at over 600whp. Wet traction isn’t the best but I don’t have a problem with it. A lot of people are going to mention the Michelin ps4s. It’s a great tire for what it is. Especially the wet traction. Grip isn’t as great as the Goodyear but it’s not too far behind it. |
05-30-2021, 06:54 AM | #3 | |
05-30-2021, 07:10 AM | #4 | |
Drives: like an old lady Join Date: Jun 2012
05-30-2021, 07:37 AM | #5 | |
* when i say hookup I don’t mean launching the car from a dig. |
05-30-2021, 09:48 AM | #6 |
If it's just a weekend fun car then put a Nitto 555r2 drag radial on it. Nitto hit a home run with these tires for all around use. You will get the same mileage as the SC3 tires and much better traction. I doubt you notice much difference in cornering ability unless you road course.
2016 NFG 1SS A8
05-30-2021, 01:22 PM | #7 |
Drives: 2018 Camaro SS Join Date: May 2019
Nitto 555 RII. A fantastic tire. Hooks well on the street and at the strip it will have you grinning.... Trust me !!!
Surprisingly good tire life as well. As was said in the above post...Nitto hit a home run !
GPI ported LT2 intake
Kooks 1 7/8 long tubes high flow cats Mamo ported 87mm TB CAI cold air box Vellosa ram air MBRP axle back E85 Flex fuel sensor Tuned by GPI |
05-30-2021, 06:08 PM | #8 | |
05-30-2021, 09:32 PM | #9 | |
05-30-2021, 10:23 PM | #10 | |
05-30-2021, 10:57 PM | #11 |
if you want to turn the car at all id opt for a 19 or 20" drag radial. no experience with nittos but they are heavily favored.
05-30-2021, 10:59 PM | #12 |
Aaron, cost difference from the 285 vs 295 is significant.
05-31-2021, 07:15 AM | #13 | |
05-31-2021, 07:25 AM | #14 |
I run 20 psi 285s at the track and the 305s I run 28 psi on the street and that keeps the tire light from popping up on the dash.
