06-06-2021, 07:52 AM | #15 |
Are you willing to disassemble the motor to do this? Plus the stock pistons are cast so if your gonna spend the money on fly cutting the pistons because thats all labor. You should just consider a set of forged pistons if your going that far.
06-06-2021, 08:13 AM | #16 |
Drives: like an old lady Join Date: Jun 2012
i like how "what cam" threads still turn into a forged stroker motor. because might as well.
06-06-2021, 09:00 AM | #17 |
The OP wants a daily driver cam not a max effort cam. There are plenty of cams out there to suit the OP's needs that will not require cutting valve reliefs in the piston. I posted 2 examples previously.
2016 NFG 1SS A8
06-06-2021, 10:12 AM | #18 |
Drives: Chevy Camaro SS Join Date: Nov 2019
All you have to do is take the heads off and use the Lindy tool to cut them. I have whatever the tool cost to cut them. Cast pistons is just fine for an N/A setup. I have mine cut at .180 and would do it again without thinking twice.
2017 1SS:Hi-Ram, FBO, OTR ram air, Circle D converter. Previous PB: 11.07 @124 1/4 7.1 @100 1/8 1.6 60’ w/2” longtubes, 95mm hi-ram, OTR ramair, flex fuel |
06-06-2021, 10:23 AM | #19 | |
For what you want as far as heads go, you would honestly be good with a set of factory ported heads from GPI, Mast, or Pray. If you absolutely wanted to have an aftermarket casting, you can look into CID, Mast, TSP, and the ones you listed in the OP. My personal opinion would be to look at something other than the Eldebrock heads.
06-06-2021, 10:25 AM | #20 |
I got asked why I didn’t do that when I went through my cam swap because I balanced the bottom end. It was easy, I used what I had and balanced a because my uncle runs a machine shop and does this stuff everyday and I wasn’t out any money on it.
06-06-2021, 10:27 AM | #21 |
Agree it's not a big deal to fly cut. Guys did it all the time and still do it on LS stuff. Nothing different going on with LT stuff. And I agree the bottom end is more then capable of handling any kind of NA power that can be made. If the rings were gapped properly for boost they would handle a lot more power with FI.
Either way it won't be needed for a cam that is what I would consider "Daily Driver". Daily Driver in my mind is something in the stage1 or 2 category with most vendors. The stage 2 with a good set of heads and intake should make 550whp on 93 octane and upwards of 580whp on E. I would avoid anything TSP that is engine related other then their headers.
2016 NFG 1SS A8
06-06-2021, 12:11 PM | #22 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
06-06-2021, 03:38 PM | #23 |
They’ve got quite a few quality issues with heads, cams, valve train parts, etc.
06-06-2021, 03:40 PM | #24 | |
Also why I always try to list them last with stuff in case somebody for some reason wanted to use them.
06-06-2021, 04:38 PM | #25 |
This!
2016 NFG 1SS A8
06-06-2021, 06:47 PM | #26 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I agree as well, TSP seems like they just don't care that much and they just have inexperienced kids working there. That's the attitude I kind of got from them.
06-08-2021, 12:34 AM | #27 | |
Drives: Camaro Join Date: Aug 2020
Proof is in the pudding and the results don't lie.
2017 Chevy Camaro Hyper Blue 2SS A8 GPI Ported Heads, GPI SS1 CAM, Rotofab CAI, Katech Ported TB, GPI Ported IM, TSP 1.78 Long Tube Headers, Elite Engineering E2 Catch Can, Chevrolet Performance Strut Tower Brace, Factory Reproduction Style 28 Wheels, Michelin PS4S
2017 Chevy Camaro Krypton Green ZL1 Rotofab CAI, Borla Cat-Back, Michelin PS4S |
06-08-2021, 09:49 AM | #28 | |
BAMF SS
Fastest H/C car has what sized headers? Fastest SBE car has what sized headers? No one has tried the victor jr heads yet, so ruling them out is moot. You're right... the proof is in the pudding. Your pudding is
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
Tags |
2016 camaro 1lt, 6.2l, cam, headers |
