Old 09-10-2018, 12:58 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Ass end pushing right
Ok so at LS Fest I kept fighting the car, does it on the street but worse on the track. During the pull my car wants to push the ass to the right and the front goes left hard. My wheel is turned almost a 1/4 turn the entire pull.
Now normal driving on the street the wheel is straight and I have no issues.
Now what I did to correct this problem was to run 3psi more in my right rear. It helped a ton.
What suspension adjustments should I make to help correct this?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 09-10-2018, 03:41 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Stock diff with clutch pack? That'll grab right if so.
I went with the TrueTrac to fight the right wheel grab - real noticeable on a road course until I switched...
Had the Clutch pack upgrade and it made it worse...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 09-11-2018, 01:24 AM   #3
P1100
Drives: 2013 Camaro 2SS
Check for even rear tire wear. I had a similar experience After replacing the drivers rear tire (bolt damage). Would pull left on moderate to hard acceleration and jump right on shift. New tire is 10/32 and original tire was 6/32. A new tire on the passenger rear solved the issue.
Checkbfront tires as well, not sure what that would do.
P1100 is offline   Reply With Quote
Old 09-11-2018, 01:53 AM   #4
2010_camaro
Has a trutrac in it.
Running a 28x10.5 15 slicks.
Wear is even.
Car only pushes under load.
The higher the boost the harder it pushes.
Old 09-11-2018, 01:25 PM   #5
Synner
Drives: cars
Possibly alignment. High boost, double nut (so to speak) the arms to avoid backing off and loosening over time.
Synner is offline   Reply With Quote
Old 09-11-2018, 05:01 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
What Rear cradle mounts are you using?
What rear upper control arm cradle bushing did you use?
It sounds like you are still experiencing deflection.
Did you get a chance to get in the other lane at the track?
bayarea408 is offline   Reply With Quote
Old 09-25-2018, 06:04 PM   #7
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man
BMR Anti-roll on the stiffest setting is what fixed my car from doing that
ZL1C7 is offline   Reply With Quote
Old 12-05-2023, 10:12 AM   #8
Thestormoverkrynn
Drives: Camaro Zl1
This is installed at the rear of the car? and stops the camaros from kicking out it's ass end to the right? On launch? Because u posted a pic of what's called a strut tower bar.. how does it control the ass end?
Andrew
Plz i need to know ..
guaranteed?
Thestormoverkrynn is offline   Reply With Quote
Old 01-13-2024, 02:00 AM   #9
ZL1C7
ZL1C7's Avatar
Thats my signature photo. Only thing that is guaranteed is death and taxes
Old 04-22-2024, 01:07 PM   #10
Get it on some scales and check your corner weights.
Especially if you have suspension mods like lowering springs etc.
Old Yesterday, 05:38 PM   #11
rsrsrs
rsrsrs's Avatar
Drives: '11 2SS/RS M6
Did you upgrade the body mounts to poly? A member in my old car club changed his with BMR. Turned out one of the body mounts was the wrong size. Once he contacted them and got a replacement all was well
rsrsrs is offline   Reply With Quote
