01-14-2021, 02:33 PM | #1 |
Streetkingz_chri55
Which kit is worth the cost
Currently my ss has
Gpi ss4 nfc Yank pa 3800 converter Bmr drag suspension 3.91 diff with jre mod Looking to go centri since I already have a na set up Was looking at Ess g3x Ecs 2200hd Procharger d1x Looking to end up with 800whp give or take if I want to go further Eventually going to go with a 416 block Anyone has any experience and can give me the pros and cons and etc |
01-14-2021, 03:54 PM | #2 |
You are gonna have to do a lot more than that to get 800!! One of my friends just did a full Whipple 2.9 upgrade with a cam and AFR heads, dual nozzle meth injection, LT's, exhaust and is a stick car and only made 685rwhp.. At 7.5lbs of boost..
Edit: corrected boost info..
01-14-2021, 08:39 PM | #3 |
Streetkingz_chri55
It don't have to make 800. I'll really be happy with 700.. but I know.. just wanna find out which blower is better
01-14-2021, 11:26 PM | #4 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
I have had them all procharger for sure
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
01-15-2021, 05:44 AM | #5 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
As long as he has the fuel system anyone of those blowers will get him to 800whp. Just spin it fast enough. I made just over 900whp with the SBE, G3X, cam, exhaust and E85. If you are going to forge the motor the 2200 will probably make the most peak power. If you are building a race car, I'd get that. If you are building a street car, the G3X or D1 would probably be a better fit. In my opinion, I'd be comparing the tuner kit prices, because if you wanna make 800+ and forge the motor soon, you will need a real return style fuel system $$$ and a real set of injectors. most kits come with weak fuel systems and junk injectors, and the tunes wont be perfect if you have a cam. Save that money, you will need it.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
01-15-2021, 07:33 AM | #6 |
Buy a ZL1?
01-15-2021, 09:12 AM | #7 |
Streetkingz_chri55
01-15-2021, 09:15 AM | #8 | |
Streetkingz_chri55
01-15-2021, 10:01 AM | #9 |
Drives: 2011 2SS/RS LS3 Join Date: Apr 2017
Currently trolling for a ZL1 as my next toy and saw your post in the classified section. My last build was an ‘11 SS LS3 making 775 whp from a D1.
You’ll need to crank up the boost and go E85 to hit your number. Your SBE with 100k miles is the weak link. If you want a high hp car from where you sit today, build it right once. Start with your block and go from there. The build in my sig cost $27k all in.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
01-15-2021, 02:26 PM | #10 |
Drives: 1999 Trans Am Join Date: Jul 2009
D1-x will hit your mark no problem.
01-15-2021, 06:38 PM | #11 | |
Streetkingz_chri55
01-15-2021, 06:45 PM | #12 |
Well TMS has them on sale this month. $5400
01-15-2021, 06:53 PM | #13 |
Streetkingz_chri55
01-15-2021, 10:32 PM | #14 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Go turbo and send it. I’m biased to ECS Bc that’s what I did on my Camaro. When I get another vette and build it up, I’m doing turbos.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
