Old 10-20-2020, 10:06 AM   #1
Smoke-in
Drives: 2018 Camaro SS 1LE
Advice on Half Shafts and Drive Shaft
Looking to upgrade my Half Shafts and Drive Shaft. Need some advice from you seasoned drag racers. I have a 2018 SS 1LE. Because of the M6, there is a lot of pressure on the stock set up. Do I go aftermarket, or stock ZL1? What is a proven brand to go with? What will hold well with 550 hp at the wheels?
Smoke-in is offline   Reply With Quote
Old 10-20-2020, 11:36 AM   #2
asthmamax11
asthmamax11's Avatar
Save your $ and try to get the ZL1 DS
Aftermarket drivetrain prices are absurd
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-20-2020, 11:42 AM   #3
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
I am supercharged and an M6 with drag radials, this is what I have and have had no issues. I am however pulling the trans for a rebuild this weekend, something internal let go and doing a clutch while I am in there.
DSS axles (less expensive than Gforce)
Gforce aluminum drive shaft (I think they are the only ones who make a DS for M6, but I talked to Gforce yesterday and they are on hold making them because of supply issues and moving locations. Perhaps there is stock out there though)
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 10-22-2020, 09:17 PM   #4
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Like @Jhunsberger, I’m also running the GForce aluminum shaft, but A8 instead. It’s been smooth as butter so far, but I’m nervous that maybe I should have went chrome moly instead. Just don’t know how long the aluminum will withstand high HP at the drag strip (not that I go very often).
The GForce Outlaw axles are pricey but worth it IMO since they upgrade the stubs and CV joints too. Otherwise you’re only as good as the weakest link IMO.
Old 10-29-2020, 09:12 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
GM went 2 piece for a reason and that was to reduce transmission of drive-line vibrations. I would try a ZL1 drive shaft before I spent 1k on a 1 piece Aluminum. If this was basically a race car application then yea, for sure get a chromemoly... but for a street car that sees the track once or twice a year imo the ZL1 makes more sense.
2016 NFG 1SS A8
Options-2SS Leather/NPP
