Old 10-06-2020, 11:50 AM   #1
Smoke-in
Drives: 2018 Camaro SS 1LE
1LE Half Shafts-Drive Shaft
Does anyone know if the Half Shafts and Drive Shaft on a 1LE is up graded from the standard SS?? Do the ZL1 and 1LE share the same shafts if they are M6??
Trying to figure out if my 1LE will hold 550 RWH without total abuse.
Smoke-in is offline   Reply With Quote
Old 10-09-2020, 02:18 PM   #2
appleman22
Drives: 2017 1ss 1le
yes they are upgraded compared to the regular ss, but a little less beefy than the zl1. Should hold 550 no problem
appleman22 is offline   Reply With Quote
Old 10-12-2020, 09:34 AM   #3
Smoke-in
Thanks Appleman,
That’s what I was thinking, and hoping. Just have not found out how to check part numbers between ZL1 and LE 1 yet. I may need to visit the dealer and have them look it up.
Old 10-31-2020, 10:46 PM   #4
teesee150
Drives: Camaro
Will 1LE axle shafts bolt in on a SS? I thought they were different lengths
teesee150 is offline   Reply With Quote
Old 11-03-2020, 12:07 PM   #5
Smoke-in
I believe they are different lengths. The differentials are different. Plus the 1LE shafts aren’t much of an upgrade. Go with DSS aftermarket, or for a lot more money, G-Force.
