10-25-2014, 01:49 PM | #57 |
Drives: RS Join Date: Jan 2013
10-25-2014, 04:33 PM | #58 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Pin which picture? The interior has more cam than the interior.
10-25-2014, 08:18 PM | #59 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
It looks like they just superglued a fifth gen cluster to give the car an interior without revealing the design. You can barely make anything out of the pic.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
10-26-2014, 08:13 AM | #60 |
The instrument panel has a big tarp laid over it. You can't see anything. At this stage, the car has a working, functional interior, hence the camo.
10-26-2014, 05:35 PM | #61 | |
Drives: Kia GT Join Date: May 2014
As an aside, what would everyone's reaction be to a 4-Cylinder, Turbo Charged Camaro?
Dodge owners seem to spit on anything that isn't one of the two Hemi V8s on offer, and judging by the general response from Ford aficionados they're absolutely outraged at the presence of a 4-pot in their pony. Guys and Gals on this forum seem to not really care that much? As long as it goes in a straight line very quickly, amirite? Quote:
The only places I've found to actually buy a Camaro, Corvette or Cadillac are via grey importers. No GM warranty or service centres. Hell, do you know how many Camaros were officially sold via Chevrolet dealers in the UK in 2013? 2 I'm not even kidding. Hopefully GM wont continue they're utterly incompetent streak next year. |
10-26-2014, 06:29 PM | #62 |
10-26-2014, 06:33 PM | #63 | |
I would consider a Turbo 4 if it has a lot of torque, makes over 300 HP and is 200 Lbs lighter than a V8. |
10-26-2014, 07:02 PM | #64 | |
Drives: 2008 Malibu V6 Join Date: Mar 2008
If a turbo 4 shows up, I'd put my money on the 270-hp unit from the ATS. It does raise questions, though, because Ford's Ecoboost supposedly puts out 310 hp. If GM chooses to play that game, can they do so with a 40 hp deficit to the Mustang? I mean, sure, they CAN, but would they? I guess it's possible if the turbo 4 is the base, entry-level Camaro, but even that is questionable since the base (V6) Mustang is at 300 hp. I guess my point is this: Does GM really want ANY '16 Camaro out there that is less powerful that the lower-trim Mustangs? Maybe GM will just say, 'Screw it, we're going to top the Mustang across the board" (e.g., base NA V6, mid-range twin-turbo V6, top-end V8s). |
10-26-2014, 07:08 PM | #65 |
Drives: 68 Camaro 327ci 2SS/RS 376ci LS3 Join Date: Mar 2008
6000 Vehicle Delivered to Customer 6-23-10 |
10-26-2014, 07:19 PM | #66 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
Glass roof like the rustang?
10-26-2014, 08:06 PM | #67 | |
Opel/Vauxhall do indeed have a 300hp+ version of this engine, and its set for release in the Astra GTC VXR Extreme Edition. The standard engine as installed in the Astra is 276bhp and 295lb-ft of Torque. The current V6 engine is 278lb-ft, with the V8 pushing 420lb-ft with a manual. The 300bhp version of the 4-pot will obviously output a higher torque value, so it'll slot very neatly between the two in the range. The downside is that, unlike Ford's 2.3L EcoBoost, the 2.0L 4-pot in GM's lineup has less total Horse Power than the V6. |
10-26-2014, 10:22 PM | #68 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
But if the 4 cylinder is the base, then I think we'll see the same 270HP, 295 TQ version. The V6 is supposedly not the LFX in the current car, but a new V6 called the LGX, but still a 3.6. You can bet the engine will be more efficient than the already pretty efficient LFX, and hopefully even more powerful in HP and TQ. If the V6 can put out a good 330+ HP and around 290 TQ it will be more than good enough to go toe to toe with a stock Mustang Ecoboost. The Ecoboost will make more power down low, but the V6 will run it down on the top end. Its already been proven on the drag strip that a 2014 Mustang V6 traps higher than the Ecoboost. Combine a strong V6, with the chance that the Camaro could end up a tad lighter than the Mustang and you have a strong chance the Camaro V6 will be quicker than the Ecoboost, especially from a roll. An 8 speed transmission in the automatic will give it even more of an advantage. The turbo 4 is a good engine though, and can easily make around 300HP and 320 to 330 TQ without much of a sweat. If they price the turbo 4 and the V6 pretty much the same, as I mentioned at the beginning, then I'd expect a slight power bump to the turbo 4 to close the HP gap a bit.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
10-26-2014, 11:04 PM | #69 |
Drives: 2004 Pontiac Grand Prix Join Date: Oct 2010
When the 6th generation Camaro comes out it is rumored that the Cadillac ATS (and CTS) will get new engines which will likely also be used by the Camaro. Though part of this is to have more refined engines for Cadillac (with these engines likely filtering down to other models).
The 2.0T 270BHP and 295ft-lbs of torque engine is likely to be replaced by something that I am sure they want to be able to produce about 300BHP (while meeting the same long term durability requirements as the current 272BHP engine). Though pfadt I believe claim to have a $1,200 kit that takes the current 272BHP engine up to 367BHP. That is one benefit that you get with turbocharged engines, you can make a good amount of more power then stock for not that much money. Even if they give it only 272BHP for the 2.0T Camaro if the next Camaro is light enough people will no doubt be pushing these engines to numbers even as high as 400BHP. At the same time by continuing to offer the N/A V-6 engine they really provide two pretty different base experiences (for both the Camaro and Mustang). The torque surge of a turbocharged engine (with strong mid range punch) vs the building of torque in the N/A engines where the more you rev the more it gives you. From the early reviews while I like the new Mustang I feel that they set their sites too low and could have done something really amazing. I think that the big difference with the 6th generation Camaro is that every engine model will be considered a performance vehicle. I still feel that with the 2015 Mustang that the 3.7L and 2.3T engine cars aren'y really performance cars more of a option against something like a Honda Accord coupe. |
10-27-2014, 12:37 AM | #70 | ||||
Though, from every review I've read of the Turbo 4 Mustang, both from the USA and the UK, the Turbo 4 is by far the better corner muncher. All the low down torque is better for exiting a corner, and the feather weight engine in comparison with the 6 and 8 make it a better balanced car, too. Maybe being less nose heavy will be a selling for a 4-Pot Camaro, too. If you're not into drag racing the 4 would make an alarmingly good case for itself. Quote:
It still screaming fast by any metric and you could easily loose your license in a heartbeat. Since the ATS weighs in at around 1.5t, I'd expect the Gen6 to weigh about the same if not less. The 300hp Turbo 4 + well chosen gear ratios and I think 5s dead or possibly lower could be achieved. In fact I'll be disappointed if it doesn't match the EcoBoost mustang at the very least. |
