Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Engine Internals
Old 11-12-2019, 08:44 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
Gen5 Headers/Exhaust from PFYC!!
Stainless Works SP Long Tube Exhaust Headers for 2010-2015 Camaro SS
https://www.pfyc.com/CA5084.html
These SP (Stainless Power) series headers are physically identical to Stainless Works' other long tube headers but are assembled overseas to save you money; the hardware is the same. Made from high quality 304L stainless steel, these durable headers are CNC mandrel bent and come with 3/8 inch thick flanges and 1 7/8 inch primaries with 3 inch collectors. If you select factory connection, they'll bolt right on to the factory connection point. You can also choose a performance connection which means they are not necked down and are meant to connect to aggressive and large size cat-back systems and X-pipes sold separately. Choose from either offroad pipes (converter delete) or pipes with integrated catalytic converters installed. Backed by a 24 month warranty on material and workmanship. Comes with all hardware, installation instructions, and O2 sensor extensions if you choose catted pipes. Off road use only.
Application
2010 2011 2012 2013 2014 2015 Camaro SS 6.2L V8
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
Stainless Works Long Tube Headers 2010-2015 Camaro SS 6.2L V8
https://www.pfyc.com/CA5002.html
Stainless Works has released their newest header design for the 5th generation Camaro SS 6.2L V8. Made from 304 stainless steel, and with your choice of 1 7/8 inch or 2 inch primaries with 3 inch slip fit connectors, these headers will fit perfectly and perform flawlessly for many years. If you select the catted pipes, you'll get high flow metal matrix catalytic converters and 3 inch lead pipes to fit a factory sized exhaust system (factory or aftermarket). NOTE: For offroad use only. Not legal for use on street vehicles in some areas including California.
Application
2010 2011 2012 2013 2014 2015 Camaro SS V8 6.2L
Stainless Works Dual Exit Cat-Back Exhaust 2010-2015 Chevy Camaro V6
https://www.pfyc.com/CA5024.html
Stainless Works introduces 3.4L SS CNC mandrel bent dual catback exhausts for your new 2010-2013 Camaro. 2.5 inch mandrel bent 304 SS dual catback exhaust system comes with an x-pipe and chambered turbo mufflers that fit up to factory connection points. The system includes mirror polished 3.5 inch dia. slash cut SS tips and all clamps and hangers for easy installation. Dyno tested to add 15 rear wheel horsepower with no tuning.
FEATURES
CNC Mandrel bent
18 gauge 304L Stainless Steel
Bolts to factory connection point
X-Pipe
Exhaust Tip
Chambered turbo mufflers
All hangers and clamps included
100% American made by skilled craftsmen
Manufacturer's limited lifetime warranty
Application
2010 2011 2012 2013 2014 2015 Chevrolet Camaro V6 3.6L
Stainless Works Cat-Back Exhaust for 2010-2015 Chevrolet Camaro SS
https://www.pfyc.com/CA5001.html
Owners of the 6.2L Camaro can now enjoy the power and sound of Stainless Works exhausts too! 304 stainless steel CNC mandrel bent 3" dual exhaust system comes with x-pipe, dual chambered turbo mufflers (for fitting to Stainless Works headers) or dual s-tube turbo mufflers (for fitting to factory connection point), mirror polished stainless steel tips. Includes all clamps and hangers.
Application
PFYC is offline   Reply With Quote
Old 08-24-2022, 02:44 PM   #2
PFYC
PFYC's Avatar
Drives: Yes
Thank You for your orders
