Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 11-30-2017, 01:39 PM   #1
PFYC
PFYC's Avatar
Drives: Yes
Borla S-Type Cat-Back Exhaust Single Tip For 2016-2018 Camaro SS from PFYC.com
Use Promo Code: SAVESIX for more discounts
PFYC is offline   Reply With Quote
Old 08-03-2018, 08:06 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gasses, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds. Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation.
Old 08-29-2018, 08:12 AM   #3
PFYC
PFYC's Avatar
Drives: Yes
Order yours today!
Old 03-25-2019, 12:53 PM   #4
PFYC
PFYC's Avatar
Drives: Yes
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
Old 10-16-2019, 11:10 AM   #5
PFYC
PFYC's Avatar
Drives: Yes
Thank you for placing your orders with PFYC.
We appreciate your business!!
Old 11-15-2019, 08:12 AM   #6
PFYC
PFYC's Avatar
Drives: Yes
Borla 140689 Camaro SS 3" W/ Single Tips 2016-2018 Cat-Back Exhaust S-Type
https://www.pfyc.com/borla-s-type-ca...camaro-ss.html
Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gasses, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds. Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship.
Application
2016-2018 Chevrolet Camaro SS 6.2L V8 Automatic/ Manual Transmission Rear Wheel Drive (RWD) 2-Door (EXCEPT Convertible) equipped with Single Split Rear Exit Exhaust Non-NPP.
Old 11-15-2019, 11:16 AM   #7
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Is there a kit without the mufflers?
ssmofo is offline   Reply With Quote
Old 11-15-2019, 11:24 AM   #8
PFYC
PFYC's Avatar
Drives: Yes
https://www.pfyc.com/borla-60607-connection-pipes.html
https://www.pfyc.com/borla-60610-connection-pipes.html
