10-04-2023, 08:48 PM | #1 |
Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
how accurate is the Engine Oil Life System?
I decided to follow the engine oil life system and change my oil. I last changed my oil October 2022 at 4400 miles and today, October 2023 I changed it at 9300 miles, as the Engine Oil Life System indicated 2% oil life left.
The oil on the dipstick looked fresh, however when I emptied the oil pan it came out black and looked to be well used. I am using Mobil 0w40 ESP x 3 Dexos 2 oil with a PF64 filter on my 2022 SS 1LE. The Engine Oil Life System according to the manual computes oil life based on mileage driven, engine revolutions and engine temperature. Are there any other factors that this system uses? After how many miles are you guys changing the LT1 motor oil if you are driving the vehicle relatively easy and not too hard?
2022 Camaro 1SS 1LE 6-speed
10-04-2023, 08:58 PM | #2 | |
2020 Shadow Gray 2SS
I would definitely change my oil a bit more than you are, I go 3,000 miles max or 10 months, whichever comes first (for me it is always the 10 months as I only drive about 2,500 miles per year)... If you are tracking the car at all then you need to change it even more often than that... Oil is relatively cheap, the LT1 Engine (and components) in your $50,000+ 1LE are not... Change your Rear Differential fluid as well, it is super easy...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
10-04-2023, 09:06 PM | #3 |
Who Needs to KNOW?
It's a good guide.. but dont make oil changes a place to save money! 4-5K miles w good quality synth oil is about as much as i'll go.. 10qts of Mobil 1 is what.. $50 n change on sale?
ing for grip.
10-05-2023, 05:48 PM | #4 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
The oil life monitor was at 4% on the 7k mile oil change sample so I would say that it might be overly conservative but for warranty purposes I would recommend following it to cover yourself in case you end up needing engine warranty work like I did last year (failed lifter requiring replacement of a lot of internal engine parts and a head). In my case they didn't ask for oil change records but it was good peace of mind that I had them available. |
10-05-2023, 06:05 PM | #5 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
I would think a 10qt oil capacity in these cars would be able to go longer than the older LS motors with 5-6qt capacities but I suppose it's different now with DI vs PI. I used to do 3k on my LS cars with 5-6qt but I know for a fact I could have gone longer.
That's good info you guys have with Blackstone samples
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
10-13-2023, 11:39 AM | #6 |
Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
i have about 3400 miles on my SS driving mostly city, the oil has about 2700 miles with 29% oil life. That puts me on track for 1yr/3500 mile oil changes, which is pretty conservative. I would go by it, GM patented the algorithm for it.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
